Cartersbanshee
About Cartersbanshee
  • Birthday 03/28/1989
    Southern Illinois
  • Interests
    Riding ATV's
    1990 Banshee- Red &White- Mods: Bored.30, K&N Air Filter, V-Force4 Reeds, TORS removAL kit, Ehs racing lid, Pro Flow adapter. Coming soon, T5s!
Recent Profile Visitors
676 profile views
Cartersbanshee's Achievements
  1. ah, I feel dumb...was the Cdi. . . Now dealing with a overheating issue, assuming she to lean. Hopefully going bigger on the mains will fix the issue! Ty ALL!!!
  2. Is it possible for the flywheel to be bad even if it dont rattle? Can a Chinese brain an coil foul plugs? I'm not the smartest but its crazy...cant say for sure plugs are fouled but unusable after dies...new plugs it fires up...Its riding season an missing rides over something dumb..
  3. Was the same issue before rebuild. Didnt even need rebuilt, just did it because I thought it was the problem. Yes. I've tried stalling it an restarting, Tried bypassing key just to try it..always the same. Kill it, wont start until new plugs..its crazy. Ran this issue across many local ppl an tried almost everything.
  4. 90 Banshee Havent needed ya'lls help in 4 years, gotten pretty good with jetting an rebuilding her an stuff but I'm mind boggled an spent a bunch of money only to get no-where. So I got this wierd issue, she runs an starts fine but soon as you kill it she fouls a plug it seems like. Put new plugs in her she fires right up an then when u kill it an instantly try to kick it again she's dead. New plugs, shes good again until dead.... Shes got good compression, just put her back to standard. Tested stator ohms are almost all in spec. New stator not oem but it reads ignition 22.5, pickup 112.5, lighting 038..ignition is alittle high. New brain not oem, new coils not oem, only thing I havent replaced is the flywheel but it seems tight an dont hear anything loose when shake it. Timing plate back to 0 right now until figure out the problem, I've tried 2,3,4, didnt solve didnt problem. Jetting is pilot 27.5 with 300 jets cause that's where it should be to me..went all the 360, 10 at a time trying to maybe lean it out. Thinking maybe it was to rich fouling plugs. Running klotz 40:1 at the moment. Can add more details if need but honestly I think it's a electrical problem that I cant cure. Eye is in spec. Just got Kevin's wiring harness with no tors/no park brake didnt help any but it is a nice harness. Another thing I may note is that when you kick it over with the spark plug out you dont see any spark, even with fresh plugs. But screw them in an fires instantly until kill motor...so mind boggled..aggravated.. I've read everything on here an search but seen noone with this wierd problem.. Thanks to anyone that respond's or is able to help me.
  5. Thanks, I'll try it again 1-6th an see what happens.
  6. http://cloud.tapatalk.com/s/58b456c75d89b/20161224_141848.jpg? Pic of my girl <3
  7. I'm bored over 30, just figured more oil would be good..I'll go up to 32:1 though. So 1-3rd plug chop would still leave the plugs white? Didn't have much room to stretch her out but I will next week. Ordered #360 mains to see if I can richen it up.
  8. Supertechniplate with 93 octane..just figured alittle more oil wouldn't hurt :\ Didn't think it mattered as long as you were jetted for it?
  9. Update: The pipes are on an they sound/Look great. Have a question about the jetting though. I did a plug chop 1st-3rd and the spark plugs were white no color at all. #320 main jets in it now. I'm at sea level running klotz 28:1, toomey needle in 4th slot with all the mods listed. Should I jump up to like a #360 main jet to get a chocolate/black ring during plug chop?
  10. Rust inside both chambers, should I send them back?
  11. Sent from my SAMSUNG-SM-G920A using Tapatalk
  12. Sent from my SAMSUNG-SM-G920A using Tapatalk
  13. http://cloud.tapatalk.com/s/58503ebf70048/20161213_120105.jpg? Sent from my SAMSUNG-SM-G920A using Tapatalk
  14. Finally got my T5's today from Hsdracing and they already have alittle rust in the expansion chambers, is this normal? Also they have big dumb welds all over it. Never had aftermarket pipes so idk if rust is normal, I expected brand new pipes for that price..
