caleb90
    31
Everything posted by caleb90
  1. i keep multiple filters on hand. wash in diesel, then clean green and water. dry them then store them dry. oil when swaping out. i have some that are 6yr old still look good
  2. that little use. means its been sitting long periods with oil on it. yes air filter oil will break down the filter over time
  3. foam filters do break down with age, how old is it? also using gas to clean them breaks them down faster. better off using diesel fuel or mineral spirits to clean them
  4. green coolant distilled water. 50/50 all ya need
  5. just like the quadsport 230
  6. site sponser alloyboltz.. use oem bolts for engine mounts and suspension
  7. almost through my break in tank of fuel. decided to check compression, 130 psi both sides. 1400ft elevation 23cc 4 mill domes .50 squish. seems low to me. thought i should be at 140 150psi
  8. considering buying brand new, oem or aftermarket. who has best prices?
  9. when i got it home last yr Sent from my SM-G920V using Tapatalk
  10. tear down started last november. after months of finding parts, getting bad parts,fitting aftermarket parts ect. its finally together, took it for a little break in rip. Jeff's dune port with slp pipes, good god the mid range. still long ways to go but its rideable. need new plastics and case covers and small misc bling. Sent from my SM-G920V using Tapatalk
  11. didnt we go over this months ago?
  12. my blue plastics are faded in places, not looking to spend money for new. any of you guys try the heat gun method? i tested a small spot last night and it does seem to work.
  13. i got rid of the oem thumb throttle and bought a used throttle for a raptor 660 off ebay. much smaller than stock one
  14. how yall running your wiring harness? just put my south texas harness in. ran it oem location, air box tabs in between carbs then over motor under the tank. any different ways for a cleaner look?
  15. my fmf's i bought used fit perfect. no shims no bs
  16. well i dont like being wrong, but 11/16th worth of washers fixed the issue. this is the first set of brand new pipes ive bought for a banshee, and exspected more for the money. i see even cpi's do it, crazy to think this is the norm
  17. left side and right side. right side is about perfect Sent from my SM-G920V using Tapatalk
  18. also my seals are sitting flush on the cylinders right now.. why i think its tweaked
  19. thats crazy. for 600 bucks the things should fit part near perfect
  20. i would need about a 1 inch spacer, its that bad.
  21. not being dramatic. the fmf's i took off fit like a glove. some thing is tweeked enough to were it started to rip the rubber on a brand new exhaust hanger. just frustrating
