Hoppedupandcutdown, I have have the black and yellow from the stator unplugged right now. I checked AC&DC at the black and yellow wires and nothing. What to you mean by unplugged
The one I bought was from ebay not sure if that's why it's not working or if something else could be wrong. Does the flywheel have anything to do with the lights while the bike is running
Ok thanks for your info I will get a new stator any place you recommend. The fly wheel doesn't have anything to do with making voltage while the bike is running does it.
I even checked for voltage at the wires for the brake light while bike is running and nothing
I have no voltage at the yellow and black wires coming from the stator with the bike running, with a DMM I have tried 3 DMM just to make sure it wasn't a DMM. Is it possible that the stator I bought is bad
My brake light bulb is good my fronts I have disconnected since they broke when I crashed a while ago. But I have no voltage going to any of lights. Is there a way to test the voltage regulator
My lights were not working so I thought I had a bad stator so I replaced it installed new one and I have no voltage to my lights still.
Wires from stator on the bike right now(new stator)
Yellow to Black from stator I have 0.2-0.3
White/red to white/green I have 117
Green to Red I have 13.9-14.4
Not sure what else to check made sure all grounds are good and even check to make sure the flywheel is grounding good.
Any would be great thanks
