maggdog
Recent Profile Visitors
1,247 profile views
maggdog's Achievements
HQ Soldier
HQ Soldier (2/5)
3
  1. Tools you need: I used gopro adhesive (it can hold a camera will hold this little piece) and I cut the adhesive to form of base mount: Also. You can drill 4 holes to the plastic and use 2 ziptight Mount the sensor: For the magnet. you need to take of the wheel and drill a little the wheel for seat the magnet and will epoxy works better with this. You will got the idea Check sensor for making contact with the magnet: Now you can mount the dash/speedo at the base Making contact: Check on dash: It doesn't has contact you can bent the place a bit: Check again: Done! This is a basic dash only has: Clock, current speed, odometer, trip distance(resetable). Doesn't has light for the night but still working You can adjust the circumference: I take my smartphone with a speedo app and i run With this table I used some of those numbers until match or are close with a gps speedo Not will be exactly the same but will similar thats the idea Sent from my VTR-L09 using Tapatalk
  2. Ok got it thanks Sent from my VTR-L09 using Tapatalk
  3. I will replace the actuator arm. I need to take off the clutch cover and left carb? or only left carb? Sent from my VTR-L09 using Tapatalk
  4. The Pro mod tranny requires some clutch work? or only cut every dog, put back and ride?
  5. https://www.dropbox.com/s/o698kos1mukqece/VID_20170501_133910.mp4?dl=0 Sent from my HUAWEI P6-U06 using Tapatalk
  6. Yep I use the sealant on the for avoid water leak on to the cylinder and I never had issues with this, just only a gasket without sealant don't work starts to leak I don't why Sent from my HUAWEI P6-U06 using Tapatalk
  7. I'll try to post a video of the crankshaft Sent from my HUAWEI P6-U06 using Tapatalk
  8. Crankshaft on stator site Sent from my HUAWEI P6-U06 using Tapatalk
  9. I've checked the spark plugs. Right are excelent color and left plug looks lean the right piston has carbon center and left not has nothing I checked the stator side and looks a little bent but don't have or find oil leak Sent from my HUAWEI P6-U06 using Tapatalk
  10. Thanks Sent from my HUAWEI P6-U06 using Tapatalk
  11. a bad stator or pickup coil, can do running bad one cylinder? I've read this in a old post but I'm not sure of this
  12. Thanks buddy Sent from my HUAWEI P6-U06 using Tapatalk
  13. On carbs boots intake or head, base cylinders Sent from my HUAWEI P6-U06 using Tapatalk
  14. Great I will do the plug chop Sent from my HUAWEI P6-U06 using Tapatalk
  15. Right cylinder looks pretty good but left is a little wet and less brown I tested the carbs and are good and sync correctly and cleaned Stock carb with 300 mains and 27.5 pilot Needle in the middle clip Fmf pipes Sea level 1.5 air screw turns outs V force 4 Lid on Stock stroke Can be a air leak or? Looks good for you the left spark plug Sent from my HUAWEI P6-U06 using Tapatalk
