Craig B
Everything posted by Craig B
  1. I have a mint oem air box and lid. Could get you some pics after work tomorrow.
  2. I just bought new OEM blue rear plastic last week.
  3. Carbs are 35mm Pwk's and mains are 148. I'm @ sea level
  4. Should I try running 50:1? Never ran that small amount of oil before.
  5. This was on Sunoco purple. I haven't noticed a difference between the 2. Well just the price. Paying 60.00 for 5 gal. of the purple. A 5 gal. tin of C12 was 78.00
  6. Was able to hit 5th and was quickly running out of real restate . It was pulling good. Not many places where I ride to get in 5th or 6th.
  7. Been slowly picking away at this. Wound up changing oils [ castor] because pilot jets were clogging up if it sat to long. Now using Amsoil Dominator @ 32 to 1 with 110. Let me know what ya think?
  8. Sorry to hear about your wipeout. Are you the same NOS 350x from the ATC website that was having the hand coned 250R pipes made?? Nick was his name if I recall.
  9. Doesn't Vegas Jeff do seat covers?
  10. Was thinking of doing this with my pump gas build. Can they do that for a 68 mm bore?
  11. Craig B
    Shock ?
    Your probably right. Looks like I may try to sell my Alba +2 +1 arms and Elka stage 3 fronts. Everything I read points me to Axis .
  12. Craig B
    Shock ?
    I would think so too. If I'm looking at 1500+ for front shocks. Is it just better to go long travel?
  13. Craig B
    Shock ?
    So the big question is........... Would a better set of front shocks make a noticeable difference?? Like Elka stage 5 ,Axis or Fox floats?
  14. Craig B
    Shock ?
    I just bought them new from Atv Galaxy. There are set up for my weight and +2 swingarm. The front shocks only have 1 adjustment and the rear has 2. When I first installed the Sniper pipes I had the ride height low and that's most likely why it hit the silencer.
  15. Craig B
    Shock ?
    It's hard to say. I think they may be to stiff causing me bounce around. I know when I bought them they were set a lot softer than the stock shocks. I did adjust them and make them stiffer. Yet the rear must have bottomed out because the caliper hit the silencer.
  16. Craig B
    Shock ?
    I have Elka stage 3 on the front and rear with Alba + 2 a-arms. Not sure if my shock settings are good, but I am getting my azz kicked in the Whoops!!!! These are large whoops and plenty of them. Should I looking at something different like Floats or LT a-arm. My setup seams ok at lower speeds but getting me beat up trying to go fast. Thanks for any info. Craig
  17. Driveline folks are good people to deal with! I bought their lock-up clutch and 68mm cyl. kit.
  18. I have a set that I have been running. Seem like a good tire and the price is right.
  19. Does anyone know what the code is for 2005 blue plastic? There are a few codes when ordering plastics. Want to make sure I get blue and not black. Thanks for any info
  20. I had the same problem. I just ran that bitch and it self clearanced 16 tooth would need some work.
