SplitSide
SplitSide's Achievements
  1. Got my chariot throttle looks brand new thank
  2. Looking for a set of shearer bb out the same side left or right side. Thanks
  3. It's runs on vp 110 and Matt said he didn't touch the carbs k&t set them up and talked to them and he said that's the way he sets those carbs up at 5000ft in Utah
  4. Yeah Matt said to run 14/43 and running 110 fuel. What do you think with the needle it's the leanest one 6fj41
  5. It's a buddies quad Matt shearer was the last one to work on it. We did a leak down test last night was good. Ya that's what we thought the pilot jet was pretty high has a build sheet on it I'll see if I can find the fourm page and post it thanks for your help
  6. Have 421 cub have trouble launching falls on it face when you drop the clutch out of the hole. Has 145 compression timing +6 drag port gearing is 15/42 41mm flat side mikuni carbs shearer oof pipes 65 pilot jets 260 main 6fj41 needle 2600 elevation in Canada
  7. You can get peps for a no link set up
  8. What's everybody running for a rear shock with a no link swing arm. Other than a Marvin shaw thanks
  9. I there was wondering if they are any good never really heard anything about them. Just seeing if they were made for a certain build thanks
  10. Can you run that with a no link swing arm
  11. You still have this motor and if you do does it have straight cut gears thanks
