Hi again guys wondering on best pipe choice for a 4mil, 66mm bore, 21cc domes, +4 timing, mild port job, vforce 4.
Currently running FMF gnarlys & powercore 2s... not really sure theyre the right pipe for the job.
Wondering on best carb choice for a 4mil, 66mm bore, 21cc domes, +4 timing, mild port job, vforce 4. Running 50/50 av gas & shell v-power (99 RON)
Currently running 28mm PWKs, is there a better choice?
So a guy i know has blown his piston in his banshee, only on the right hand side. It has a hole in the top & melted the tip of the plug. When built the motor was leakdown tested & held overnight with no problems. The only fault you can see is the plug thread cap had come off & was in the plug cap. Could this being loose & vibrating cause the hole? Misfire & then big ignition?
