I just contacted the vendors and asked to cancel the orders for stock parts lol. Should have researched more . Will be buying the pro design set up . Thanks for the help man. Hope the venders don't try and pull anything. Whoops
The set up is doing the same thing as the stock set up. Well it has a clamp that holds it to the flange . Guess it is a better set up over stock. Shit . Wish I seen that before I bought all OEM parts off eBay.
Just ordered all the parts needed to run a foam duel stage filter set up. Cage, uni filter, peice that goes at top of filter, some old PJ1 filter oil also. I don't trust the K&N in the dust I ride in . Consider that ditched .
Also noticed with throttle cracked on a roll it hesitates just like my YZ did with that stupid throttle position sensor set up. I adjusted air mixture screws on carbs after changing pre mix to 36:1. Ended up a two turns out on each . Come to find out that's what the manual calls for . The bike need choke to start when cold so pilot must be close or spot on. I need to look over the service manual and read about the stock carbs.
One thing I'm not use to any more is the ground clearance on these sport quads lol. My Polaris RZR 900 has 16in ground clearance with 3 inch lift and 30 mayhems .
just read threw service manual going to check carb sink tomorrow and adjust chain. Pretty cool how the crank cases are set up on the banshee . Different but well thought out for service wise , crankshaft etc .
I would never go by what they say jetting wise . There jetting is just a window to get started with . Literally everything effects jetting . Temp, humidity, elevation etc etc . Best way I find is plug chops with fresh plugs.
For now I just want to ride tomorrow with a safe mixture with out checking jets and what not . Bike runs great and idles awesome . No bogging etc . When I put pipes on I'll need to rejet the mains so I'll clean the carbs and check reeds etc . Maybe even install new reeds for the hell of it I'm sure it could use them . What's a few bucks for reeds and gaskets .
Well the machine is bone stock so I would think stock size jets . Guy has been running 32:1 he said . Honda oil. What's meeting with jetting mean? Typo? Lol.
I have all of those toys already . Even have a crank installer . Yes I use the proper tools to install my cranks not a Mallot or block of wood lol. Thx
Haaaa. To funny . I'm just doing pipes that's all prob over the winter . Yea been reading threads also. Hope I don't have to mess with jetting going to 40:1 . Also has that stupid K&N on it so may have to idk. All I know is the thing smokes pretty well when wide open but that could be oil burning off in muffler or pipes. I'll do some plug chops to make sure I'm not to lean.
