Johnd267
Johnd267 last won the day on September 20 2015
Johnd267 had the most liked content!
    2000 Yamaha banshee bone stock
Johnd267's Achievements
  1. Hey who am I to judge I just spent 17k on a razor lol Cool quad though for drag and sand !
  2. Why would someone invest 18k in a quad ? That's just flat out stupid lol
  3. Got quite the cart going at Rocky Mountain Good times
  4. Got the pro design set up on the way also new chain and sprockets . Rockymoutain atv is where I shop most of the time.
  5. I just contacted the vendors and asked to cancel the orders for stock parts lol. Should have researched more . Will be buying the pro design set up . Thanks for the help man. Hope the venders don't try and pull anything. Whoops
  6. The set up is doing the same thing as the stock set up. Well it has a clamp that holds it to the flange . Guess it is a better set up over stock. Shit . Wish I seen that before I bought all OEM parts off eBay.
  7. The guy cut the stock cage to put the K&N over so it locks in the box with the Lid . Kind of hack set up. May be causing my low end bog idk.
  8. The plastic cage that the filter goes over . Putting the air box set up back to stock . Using duel stage uni filter though.
  9. Sure send me some shipping money threw PayPal and it's yours man. I'm johnshobby on eBay so you can see my feedback .
  10. The stock cage you know what I'm talking about. I'm putting the air box back to stack set up . Rocky Mountain has a Fitch check it out.
  11. Just ordered all the parts needed to run a foam duel stage filter set up. Cage, uni filter, peice that goes at top of filter, some old PJ1 filter oil also. I don't trust the K&N in the dust I ride in . Consider that ditched .
  12. Also noticed with throttle cracked on a roll it hesitates just like my YZ did with that stupid throttle position sensor set up. I adjusted air mixture screws on carbs after changing pre mix to 36:1. Ended up a two turns out on each . Come to find out that's what the manual calls for . The bike need choke to start when cold so pilot must be close or spot on. I need to look over the service manual and read about the stock carbs. One thing I'm not use to any more is the ground clearance on these sport quads lol. My Polaris RZR 900 has 16in ground clearance with 3 inch lift and 30 mayhems .
  13. Dame kick starter fell off in the woods lol. . Noticed it was rattling and ordered the parts to rebuild it last night . So much for that .
