Juststrokeit
Juststrokeit last won the day on August 30 2015
Juststrokeit had the most liked content!
About Juststrokeit
  • Birthday 07/05/1989
    2006 Yamaha Banshee, Hot rods 4 mil Long rod crank, dune port, bored .040 over, vforce 3's, +4 timing, FMF fatties, stock carbs, stock swingarm and suspension.
Recent Profile Visitors
848 profile views
Juststrokeit's Achievements
HQ Soldier
HQ Soldier (2/5)
119
  1. All pm's sent and/or replied to.. Sent from my iPhone using Tapatalk
  2. The pipes are in worse condition than I remembered.. One rewelded tab, the other one is cracked, and there is two pretty good dents. But no holes.. $435 shipped buyer pays fees Sent from my iPhone using Tapatalk
  3. Pipes are pending... I know someone needs a turn key carb package deal... I'll even throw in a boost bottle and used gaskets for an extra free fifty free.. [emoji6] Sent from my iPhone using Tapatalk
  4. It's all good.. I am willing to negotiate but I'm not gonna give em away.. Hahaha.. Sent from my iPhone using Tapatalk
  5. http://www.worldwideperformance1.com/category/CPI-PIPES.html Looks like bare steel are $530.. Not chrome Sent from my iPhone using Tapatalk
  6. Even with silencers? Sent from my iPhone using Tapatalk
  7. I have a set of small bore inframe cpi pipes. Chrome and stamped. They do have a couple dents and some scratches. There is a spot where the spring smashed into the pipe and is kinda rusty, but no holes. Comes with silencers too. They need repacked and one silencer needs drilled and tapped to remount it. $535 shipped buyer pays fees Also have a set of Keihin pwk 35mm carbs. Comes with jets, intakes, throttle cable and brand new UNI filters. The throttle cable has a slight "kink" in it, but operates fine. $450 shipped buyer pays fees. I can have pictures of carbs tonight. Sent from my iPhone using Tapatalk
  8. Hahaha.. I blew that bearing and replaced the transmission and bearings.. Now my first oil change after the bearing blow out I find that peeking out of my drain plug hole.. Sent from my iPhone using Tapatalk
  9. Well that bearing just came apart on me a few rides ago.. I replaced it.. Maybe I didn't see the debri in the bottom of the case when I changed that bearing... Sent from my iPhone using Tapatalk
  10. Oh I think I understand! My bad.. Didn't think of that Sent from my iPhone using Tapatalk
  11. Inside? So it's not that important? Sent from my iPhone using Tapatalk
  12. What exactly are you talking about..? I'm thinking it's either 25, 8, 10, or 11..
  13. Last time I had the banshee out it ran good. Really good. I finally got a day off so I was gonna do some maintenance. Drained the oil and when I was about to put the drain plug in, I seen a chunk of metal hanging from the hole. Used pliers and pulled it out. I am guessing it's a spacer piece in the transmission between gears. What do you think? Sent from my iPhone using Tapatalk
