98_sheester
Everything posted by 98_sheester
  1. Man i just sold a set of white plastics too but really either white,red or like vrx and purple would look good
  2. Your jets prolly arent correct in the carb but yes do a leak down test and better get those cylinders checked out first kiddo
  3. Yup if its stock piston should start with a "513" but if you can put that number on here we can tell you the piston size
  4. Yeah i mean fox shocks are nice i want a set myself but i mean elkas are just as popular for a variety of bikes
  5. Yes thats the brain and i would unplug it from park brake and the box on the carbs themselves
  6. No way please do not pin stripe flames unless that person is excellent. But do white and gold frame with some black arms and axle gold wheels with black hubs theres so many options but i personally think white is only way to set the gold off
  7. You want the elimination kit soon but unplugging it should be fine til you get the kit if its soon
  8. As stated radar said the resistor caps under 5ohm are just really protecting the cdi box (pretty much the bike brain) if one of the plug coils were to foul out and start missing or plug itself id assume would prevent it from burning up is what i got out of the info so i guess its a good idea but not necessary.....
  9. Yes white plastics black frame with some gold wheels would look slick i think personally
  10. Did not know this i learned something as well
  11. Well i would get rid of the junk tors first its gonna cause alot of headaches but deff unplug if you havent that might be some of the problem
  12. I run the stock coil with br8es just fine ive never had to replace my caps but they make b8es also but like i said ive never switched caps on my stock coil
  13. Do a leak down test and compression test. Also what mods do you have for jetting. Are you getting good spark. Are your carb slides in right
  14. If the bike is running bettsr with the choke out you might be a little lean usually...also when you get your slight bog does it hesitate and not wanna go faster or does it hesitate and then goes?
  15. Use tapatalk also it works well to upload pics but id get some 27.5 pilots to put in there also would get a new throttle cable with the tors eliminator kit if it didnt come with one. And id clean and oil your filters before your next ride so you start sucking clean air
  16. 1. Set of stock reeds and cages 60 shipped 2. Stock intake boots and boost bottle 30 shipped 3. Stock axle with washers axle nuts and 1 lock nut 50 plus shipping 4. Stock thumb throttle 30 shipped 5. Stock shifter 15 shipped 6. Blue tank and rad cover 25 a piece shipped
  17. What jets are you using as your pilots
  18. Are you saying you can kick it over past a quarter or it wont kick over now? Take your cover off and check the kicker idler gear...is there trans fluid in there lol
