98_sheester
Everything posted by 98_sheester
  1. Id go middle clip with 27.5 pilots and see what she does Do your slide run when its like this or no
  2. Yeah i mean they do good work just expensive but seth did those peps i sold it took him 3 weeks but he told me it could take that long lol
  3. Back the tang off a little when the float is horizontal the needle should seat with the bottom of the black nipple so its not giving alot of pressure onthe spring
  4. You should have a had seth from sf racing do it man i live here in ohio and they charge out the ass and seth is a pep builder and seller at half the price
  5. If you were to hold your carb right side up with the float all the way down take it and push the float up til its level and see if the needle is seating before the float is level
  6. Do i need new arms then cuz mine are pretty squished
  7. Do you have to have a round house carrier for this
  8. Can the a arm ball joints be changed as well anyone help me on this
  9. That noise might be from early deto i believe i read that around here some where
  10. Id put some 27.5 or 30 pilots in it and if its closing earlier that level its not letting the bowl fill all the way adjust your tang a smidge not alot
  11. You want the tang to barley touch the tip of the needle on your float when its level it might be closed to much...try to give it 3 WOT pushes with the choke out then kick it over. And what pilots do you have and is your air screw out 1.5 turns also is your idle screw to far out
  12. Pair of works A-T dual rated shocks set up for 180lb rider and +2 arms powdercoated black. They measure 15 1/2" from center to center eyelids. Have about 5 rides since serviced (i bought em after service). 225 shipped
