e90boost0813
e90boost0813's Achievements
  1. Sorry bud was in hospital my wife gave birth to the baby and we was there few days just got back Sent from my SM-G900V using Tapatalk
  2. Still have pipes I'll pay the 200 shipped tomorrow right after work Sent from my SM-G900V using Tapatalk
  3. Looking for a set of pipes cheap for my banshee just something better than stock if anyone has anything laying around in decent shape Sent from my SM-G900V using Tapatalk
  4. All parts are good crank is sold already
  5. I have flywheel and stator with timing plate and pick up on it still 100 bucks it's your bro.. I'd go all oem not random stuff.. your flywheel wiggles I'd replace it just my 2 cents
  6. Still have blown motor
  7. Left plug is round style right is 95 96 style.. I have 87 94 cdi box and harness and stator.. harness is hacked ruined.. want to know if I just take the plugs and solder them onto the right harness and stator to make the plugs go from 95 96 to 87 94 round style would it work with the cdi box or I would have issue just switching plugs
  8. Press is 10 bucks and weld around 60 I think trying to repair until I have the 400 450 for new crank is way cheaper.. and sleeper 06 how can I tell if it's will check out good.. all bearing seem fine spin good rod bearings as well.. just some rod side to side play from Web walking out and not very much.. I can tell cause one side pin is flush with outer edge of Web and other is in some from the edge
  9. I have a crankshaft that the Web started to walk.. can I have it repressed and welded vs buying a new crank.. I also have another crank with a blown rod bearing that I got for 20 bucks off of someone.. just want to fix cheapest way out to have her running until I save coin to buy the new crank eventually and keep one of these others for a spare.. need a little help or advice I've never had any crank issues with other dirt bikes I had this would be my first messing with the bottom of a engine.. also my first time building a shee
  10. Set of chromoly j arms ebay about 500 made from fire ball racing if I'm not mistaken
  11. How's the aftermarket stator work I been told stay away from them from few members
  12. Thanks tho man all I need is good cases and my bike runs again
