370bansheeSOFLO
About 370bansheeSOFLO
  • Birthday 12/12/1989
    miami florida
    2004, stock motor, Noss machine head 21cc domes, Dmc 916 pipes, aluminum radiator
Recent Profile Visitors
702 profile views
370bansheeSOFLO's Achievements
HQ Soldier
HQ Soldier (2/5)
9
  1. why kind of leak do you speak of? ill take the stinger off and see what happens. when i did the compression test it was 117psi and held strong. Sent from my iPhone using Tapatalk
  2. i feel like the right side wants to get up and go and the left side wont, hard to explain. The bike has a thumble/sputter through the RPMs it really won’t get into powerband. Sent from my iPhone using Tapatalk
  3. LMFAO west coast florida kinda guy huh lol Sent from my iPhone using Tapatalk
  4. i swapped the reeds from left to right and the problem stayed on the left side Sent from my iPhone using Tapatalk
  5. left side reeds Sent from my iPhone using Tapatalk
  6. ok so did the ohm test everthing passed ignition coil. 18.8 pick up coil 119.7 light coil .25 Sent from my iPhone using Tapatalk
  7. watched a couple of south texas banshee vids, im going to try and trim and reinstall the coil wires, also move the needle jet up 1 more notch i have it on the 3rd from bottom maybe its running to fat causing it to misfire on the left side then im going to ohm the stator Sent from my iPhone using Tapatalk
  8. 117psi left 120 right... before he brought me the bike he swaped the coil and cdi and no change think it could have sonething to do with the stator? Sent from my iPhone using Tapatalk
  9. i pulled the reeds and they look fine no cracks and there tight Sent from my iPhone using Tapatalk
  10. parking brake was deleted, no tors system Sent from my iPhone using Tapatalk
  11. hey everyone im trying to help out a friend that brought me his 97 banshee to get it running, so he says he was riding and out if no where the bike started sputtering and didnt want to run right motor has 65.50 pistons stock carbs 300 main jets 27.5 pilots T5 pipes open airbox lid with an alba single filter so bike starts 1st kick idles perfect, issue is when you ride it it sputters and wont get into the power band i noticed normal smoke from right side stinger left side not so much and when reved doesnt feel like anything is coming out the left i swapped spark plug wires to see if it changed nothing iam getting spark on both i checked carb float heights and made sure it was getting fuel and it is i rewired some of the harness thinking it has a short due to the led lights he wired in, there was a blue wire from cdi that looked burnt so i rewired that. i did a compression check left side is shy of 120psi right side is at 120psi i also swapped right carb to left side to see if i got a change fired right up idled good as long as i held the choke tube with my finger but again nothing changed with left cylinder ive been on it for 2 days now and at my wits end any advise would help big time, in which way i should look next thanks guys Sent from my iPhone using Tapatalk
  12. a little diff but same thing 927 said it mounts to grab bar Sent from my iPhone using Tapatalk
  13. ill take a picture when i get home and post it about 30min Sent from my iPhone using Tapatalk
  14. i lived here my whole life i see post like that all the time lol Sent from my iPhone using Tapatalk
