bsock
About bsock
  • Birthday 01/28/1987
    Dayton, Oh
    2006 Special Edition -Shaved Head-V4's-InFrame CPI's-ProDesign Adapter-UNI Filter-No Lid-Plate 4*-Kenda Kutter XC's-ODI Clamp On Grips-ASV Shorty F3's-XFR Nerfs-PRM Rear Grab Bar-SS Extended Brake Lines-Alba Intimidator Bumper-Alba Bead locks-Alba +2 A-Arms-Full Skidplate-TM Case Saver-PowerMadd Handguards-Protaper ATV High Bars 1 1/8"-LSR +1 Stem W Anti-Vibe Clamp-Dominator Axle-Billet Basket-High Flow Water Pump-Woods Clutch
bsock's Achievements
  1. Well I re set float height and placed clips on second notch from the blunt end re synced carbs and away she goes! I might try the 3rd notch to see how it acts but as of now it's back in action. Thanks to all of those that tossed out ideas!! Brandon
  2. Got everything buttoned up syncing carbs and found the brass jam nut stripped. Needless to say I'm waiting on a replacement. I'll be in touch when it shows up. Brandon
  3. Thanks guys! I'll be checking float height tomorrow and lean the needles and take another crack on it. I'll be back with updates. Brandon
  4. -Shaved Head-V4's-InFrame CPI's -Filter Adapter-K&N w/Outerwear -No Lid-Plate 4*- I gapped the pickup, did not gap the new plugs.
  5. Fuel lines good. Checking float height next and leaning the clips. I don't have anywhere to ride to do a wot run through all the gears. I had 3 good days of riding few hours each and the plugs were brownish in color not black not white if that makes any difference. Today just seemed as if when I go wot it's just complete bog. But it boggles my mind because a month ago when it was a little cooler this thing was a wild ride! I understand they can be fickle but shew did not know that bad. Still trying to grasp the big picture sorry for all the questions but im the only banshee around here local. Brandon
  6. LEFT 149 Psi. RIGHT 142 Psi. Not sure what the actual CR is stock pistons and head milled .030" Brandon
  7. Been 10min have yet to drop even half a PSI...... Brandon
  8. I am if you read, just adding info as I go. Thanks. brandon
  9. Yep just checked long grooves to inside. Both slides smack down new cable I lubed. Just synced them before I went up the road and put in new plugs also. Seemed to be a Pain to sync this time also. Brandon
  10. Well just wanted to take a ride up the road and now I can't get this damn thing to idle down either I keep backing the idle screws out and it keeps idling back up. Don't know if that's another issue besides doing a leak down test? This thing ran do good now it's like a downhill slope. Im going to start tearing it apart for the leakdown but any other ideas would be nice also. Thanks. Brandon
  11. Motor is not ported it's never been out of the bike. It backfired a few times also. I guess I need to do a leakdown? I'm just asking whatever you guys suggest. When it was cooler the thing ran top don't know if that holds any weight or not. Still 4th clip on needle played with air screws stopped at 1 out. Thanks! Brandon
  12. Didn't want to start a whole new thread so I'll add it here and ask. Today it was mid 70's and sunny hottest day I've rode it yet. In tight trails the bike acted fine. long flats mid to wide open would bog like crazy. Sometimes 1-2 would be fine then tip of 3rd bog. I launched in 2nd took off then bog. Would not light back up until I got off throttle and back into it again. Any help would be great. Thanks. Brandon
  13. Good deal! I'm open to any suggestions. I can for sure say that I did not measure height on the floats rather eye balled it parallel with the bottom of the carbs. Maybe I need to start there. I'll get it cleaned up and start with measuring the height maybe that is causing some issue also. It's possible I'm jumping the gun also as it isn't very warm yet. I'll look around on measuring the float height and then plow forward. Just seemed to once fall off it was done as in nothing but bog when I touched the throttle before it did the same but would come out of it with alittle feather the first ride it was a tad warmer too seems that can have a big effect also on the way these react. Thanks again to everyone helping me along the way. Brandon
  14. I put all the aftermarket parts on it. Did a compression check which was within the range but have not done a leak down test. I will run them in and back them out a turn and go for another ride. It for sure would not come back alive this time once it fell off. Last ride it would come back up. Brandon
  15. Might be crazy but it seems it got a tad worse after I tried backing the screws out... maybe I need to go back to 1 turn out and lower the needle does this sound correct? Thanks! Brandon
