Green95LX
About Green95LX
  • Birthday 08/20/1986
    North Texas
Recent Profile Visitors
1,151 profile views
Green95LX's Achievements
  1. Its a stock clutch cover that’s been cut out and a lexan window is installed. It’ll need some sort of gasket or RTV to seal the window up. https://drive.google.com/drive/folders/12-W8D65e9rFgtM1zbiDBOtgHHJDTq4gd Asking 100$ shipped
  2. And honestly I believe to the best of my knowledge they are matching. I never substituted any other case half, I only had two in my possession ever. If the engraved numbers truely do not match then that was beyond my knowledge. All I can say is that I never intentionally tried to deceive anyone. I just wanted sell these parts. I've never done anyone wrong or misrepresented. Now I'm a bad seller. Sent from my iPhone using Tapatalk
  3. They were a complete motor minus the cylinders and pistons that I got. I didn't know about the engraved numbers on the cases. I only had one set of case halves (2) that makes up (1) complete case. I never switched or substituted anything. At this point I cannot be sure that any pictures of the engraved numbers are in fact the same ones I sent because the OP by his own admission has other sets himself. They're the exact same cases, it's been shown that they are the same ones that I took pictures of and sent. If they were indeed mismatched then they were mismatched and then reassembled into a complete motor. The original two issues that he had have since been forgotten and it seems to me that it's win at any cost to prove a point now. Sent from my iPhone using Tapatalk
  4. All I know is that the cases I took pictures of and sent are one in the same. I'd never disassembled a set before so stuff like the neutral switch cover being off. I replaced it before I shipped it out. I never intentionally did a damn thing to deceive anyone Sent from my iPhone using Tapatalk
  5. I seriously apologize for this turning into a big shitstorm. But, I'm telling the truth here. The shift shaft was never stuck or drilled. I have it in the garage. I know there was a few bolts I had to remove at one point. I did so and didn't butcher it. Sent from my iPhone using Tapatalk
  6. Oh my god, that is seriously the true bottom half. The bolts that were "broken off" weren't. I drilled the heads off when they stripped and removed the stator cover. Then it was just a matter of grabbing the remaining stubs sticking out with some vice grips and twisting them out. I'm telling you that this is the true story. That is the same case half and I'm well aware of why they need to match. Let me say this again, I give you my word and god as my witness that Is the only lower case half I have had in my possession. I didn't butcher anything. You've got the case right there and you can see that it's not wrecked. Yes, i extracted the bolts. I'm not an expert by any stretch. Sent from my iPhone using Tapatalk
  7. That's not true at all I'm not a scammer, Jesus I only had one set of cases. And that's the same ones I sent. This is outrageous, I had one bottom end I disassembled and shipped the case to him. It's the only set I had. And that's the truth. If you look at the pictures you should be able to tell that it's the same set in all the pictures. Because they are. They are the same cases, I never substituted or swapped them out at any point. They're perfectly good cases for 170$ shipped. Sent from my iPhone using Tapatalk
  8. And for the record I damn sure did make the footpeg inserts myself. I took the measurements, made the little drawings and then turned them. I shared the dimensions with everyone and sold the extra ones I had. There's nothing wrong with those cases functionally. aside from the coloration which won't affect their function. Sent from my iPhone using Tapatalk
  9. There's absolutely nothing wrong with that case either, once it's cleaned good with some aluminum brightener or cleaner. They're most certainly not mismatched. I'm sorry that the color doesn't match perfectly. Don't most people paint or PC them any way? Sent from my iPhone using Tapatalk
  10. This is bullshit, they're not mismatched cases. I personally took the motor apart and it was just as it had been assembled from Yamaha. They're the same two case halves from start to finish. It's absolutely ridiculous to suggest that i bought another set of cases or case half just to ship out. Sent from my iPhone using Tapatalk
  11. I really wasnt sure where to price everything, so if my prices are out of line just make an offer.
