Blew a head gasket, trashed the pistons and cylinders. Cylinders were on the last bore size anyway. About 2 years ago I went through the bottom end and had my crank rebuilt. So I would like to keep the crank I have, and not split the cases. The crank is 115mm rod length, stock stroke, and welded. Crank feels fine and visually looks good.
I am thinking about going to a 65mm cub cylinder. Running 795 series pistons, and a stock head. I don't need to mess with the factory head to run the 795's, right? I figure I can have the head milled to what ever is ideal to run a 50/50 mix of 110 and 91 gas though.
I have in frame drag pipes, 35mm carbs, billet intakes ,k&ns already. This sound like a good way to go? Any recommendations?
