Arm.is true and straight no spider cracks on anything. Just going home now to see if I can get it adjusted properly
Sent from my SM-G900W8 using Tapatalk
Just had the same thing happen.(just putting mine back together) your actuator wont come out because the push rod has mushroomed at the end and is blocking the actuator from coming out ....sorry to say but ur gonna have to pull it out and split the cases ..That's the only way to get that rod out. YES PUT THE PANCAKE BEARING IN ! My bearing was welded to the adjuster and the rod was mushroomed and welded to the actuator. Not sure how u did yours but I let someone ride mine that did not know how to ride a clutch and shift gears properly so he either didn't shift at all or held the clutch in all the time and it seized it. Good luck !
okay update time... ended up having to do a complete tear down to just the cases. throw rod was welded to the actuator as well and mushroomed over the end of the shaft . Well that's all fixed and back together.....now having an issue with the pancake bearing (cascade)....so actuator is in when I properly adjust the clutch so the two arrows are lined up its pushing the pressure plate out too far ...and the actual adjustment screw Is too short and the jam nut wont go on. anyone herd of that pressure plate doing that ? when its properly adjusted its like 1/4 inch gap from the pressure plate and clutch boss
well update for this morning , striped the clutch side off , ball is welded to the adjuster and seems like the rod is welded to the actuator I have to order a flywheel puller and split the case ....FML
