dailydrifter
About dailydrifter
  • Birthday 02/19/1986
    South Western Ontario Canada
    2003 K&N pods, DMC916 exhaust, VF4 reeds
dailydrifter's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. A hole in the silencer would not dramatically change the power output. If your broke or cheap than a patch works.
  2. Went to install a high flow impeller today and noticed the gear looks worn. What do you guys think? Looks to me like the leading edge of the teeth are wearing out. Or is that the way it's supposed to be?
  3. Thanks for the input guys. Cleanup port and wiesco's it is
  4. So I'm going to be redoing my top end in the fall unless it pops before then . I'm thinking of either having the cylinders ported and putting in wiesco's or leaving the ports alone and installing vitos SS pistons. My number one priority is to retain the best possible gas mileage with horsepower second. Which option would be best or is there another option I haven't thought of. My mods are k&n pods, stock carbs, dmc 916, 21cc domes, +4 timing, VF4, run on 94 octane. This is a 100% trail bike. I also plan to have the bottom end freshened up during the rebuild and the crank trued and welded. Maybe some tranny mods while the cases are split.
  5. I think it's the engine that is in the z1, and f1100turbo arcticcat sleds.
  6. Could I get some close up pics of shocks? Also what are they setup for?
  7. Just to stir the pot I'm going to add my 2 cents to the whole one piece is stronger than 2 pieces welded together debate. If you were to butt weld 2 pieces of steel together assuming that the weld was a 100% full penetration and no discontinues existed with in the weld metal (slag, porosity) then the weld would actually be stronger then the parent material assuming proper filler material was used. The problem is that the area of parent material directly beside the weld becomes affected. This area is called the heat affected zone. This region of material will definitely have less strength then the weld or the original unaffected steel. So unless your willing to go to extreme lengths (heat treating and radiograpghy) to ensure that the grain structure is normalized throughout the whole part and no flaws exist within the weld then 1 piece will definitely be stronger then 2 welded together.
  8. I use the lucas oil aswell with no issues
  9. I wasn't sure if some model years didn't have material back there. Smart ass
  10. Where are you getting the lexan and seal from? I'd like to try this
  11. Did you cut out the material behind the cover that is held on with 3 screws?
  12. I just made the switch from stock length to -2. It is awesome in the trails. It makes popping the front end up over fallen trees so much easier as well as turning into corners. I wouldn't recommend it if the trails you ride have a lot of steep hill climbs though
