Scrubby
1 Follower
About Scrubby
  • Birthday 03/31/1972
    Glen Burnie , MD
Recent Profile Visitors
835 profile views
Scrubby's Achievements
HQ Soldier
HQ Soldier (2/5)
10
  1. yep, spoke with the owner awhile back, whats out there on the shelves and their store is it. they are retiring.
  2. get em while you can, Prm, is going out of business.
  3. the front fender supports can push the fronts up or down. the black ones behind the wheel., make sure they are level at the bolt holes. then make the plastic hole line up and put the bot back in.
  4. Why is there 2 different orings ?
  5. Did you mean idle screws? if you cant explain what your adjusting you probably shouldnt be adjusting it. till you know what its called and what it does.
  6. Could your stem, upper hoop be knocked back a bit? I know mines back 1/ to 3/4 of an inch. and my tie rods do touch but only at full droop, compress it about an inch it clears. im actually going to drill the arms for zerk fittings when I take em off to replace the bushings and pins next week, so I can flush out the grit. I use 2 sets a year. but I had ole funky pins, Alba is sending me new style pins with the bushing kit, so we will see.
  7. if its worn, you will see the grooves once you inspect it. some is ok, deep is when its time for replacement.
  8. My friends hate following me because of the 927 also. Jeff says he gets acid stomach from the taste.
  9. Its a stock length, the caliper is in a different place now.
  10. How long is your brake line?t installed my leagers arm and the stock line is like 8 inches too long now.
  11. Step up to pc, better graphics, purpose built with everything else. all the consoles are repeats of the franchise.
  12. ive had valve covers discolor like this , but it was caused by something, that normally doesn't discolor aluminum. if he cleaned with the same thing, it would make sense why the 1 case is a different color.
  13. I have a possible explanation to the discoloring. Green, How did you clean the case before sending?
