ftball86
About ftball86
  • Birthday 09/15/1978
    2001, Blue, Toomey exhaust
ftball86's Achievements
  1. Been going to Ocotillo Wells the past couple of weekends, this would be my first time to Glamis, are you showing up Friday night or Saturday morning? Sent from my iPhone using Tapatalk
  2. Strm Trpr, I don't don't know anything about the engine, the guy I bought it off of said he never rode it so he's selling it. How do u know it has after market head, does it look different than stock? Sent from my iPhone using Tapatalk
  3. I swapped the tors and adjusted/synced the slides and it idles no problem Sent from my iPhone using Tapatalk
  4. TORS is still installed, but the wires have been removed Sent from my iPhone using Tapatalk
  5. Everything is coated in oil on the back Sent from my iPhone using Tapatalk
  6. I used a ratio rite, filled it up to 32:1 under the 2.5 gallons twice and then filled the can with 5 gallons of 91. Sent from my iPhone using Tapatalk
  7. I think it way too rich, it won't idle, have to keep a little throttle just to keep it running. If I put my hand behind exhaust it turns black from oil, and if I pull the choke it kills it. I will pull carbs tomorrow and figure out what number jets I have installed and let you know. Sent from my iPhone using Tapatalk
  8. Is 140 a good number? Sent from my iPhone using Tapatalk
  9. Plugs worked, O'Reilly's rents compression test sets so I did that just to check (140 per side). Thanks for all the help Sent from my iPhone using Tapatalk
  10. Sorry meant to say plugs Sent from my iPhone using Tapatalk
  11. Carbs were wet, I don't own a compression test set Sent from my iPhone using Tapatalk
  12. Going to store to get new ones, I'll keep you guys posted, thanks for the help Sent from my iPhone using Tapatalk
  13. And I get a blue spark from both Sent from my iPhone using Tapatalk
