Gender
Location
Wisconsin
My Banshee (optional)
1997 Banshee. Mods: Stock Air box no cover with Pro Flow adapter, K&N filter, and outerwear. V-Force 4 Reeds. Hotrods +4mm longrod Crank w/ Maxload Bearing. Wiseco 11882 Pistons. Garage ported stock cylinders. Gasket matched case. Cool Head w/ Driveline Performance custom domes. Pro Circuit Pipes and silencers. Cascade clutch disengagement adjuster (pancake bearing). Pro-Mod transmission. Mull Engineering water pump w/ billet gear. Adjustable timing plate @ +4. Racetech 200w dual output stator, 1 a/c circuit, 1 floated ground regulated d/c. Custom wire harness, fuse block, and relay box for d/c circuits. YFZ450 front brake calipers. YFZ450 front brake master. LED tail/brake light. PRM Desert II front bumper. Fullflight +2 +1 A-arms, modified mounts for YFZ450 shocks. Alba 1" front wheel spacers. Renthal handlebars. Moose clutch lever. Alba nerf bars. Parking brake eliminator. Armadillo Six Pack Rack rear bumper. Summer setup: YFZ450 front shocks. +4 Lonestar show chrome swingarm. 40mm axle. Dual piston caliper. Cut stock plastics in white. Winter setup: Stock front Shocks (lowers frontend with modded A-Arms) Stock swingarm. Durablue Eliminator +2+2 axle. Tusk +1 3/4 rear hubs. Stock uncut yellow and red plastics,
Recent Profile Visitors
4,230 profile views
Atomic Monkey's Achievements
HQ Soldier (2/5)
20
It meant to try advancing with the stock plate to get a result because it sounds like the op is ready to try things. If the result is not what is expected... as in what you have at that point, there is no money wasted. As far as a budget goes... is there such a thing when it comes to working on these things? Lol!
Posting up another link to a short vid that a buddy took while running around the yard after rejetting... the end makes me laugh... Braap! https://www.youtube.com/watch?v=gYAfwYqN8go
- 193 replies
- cylinder porting
- racelogic template
- (and 3 more)
ISO/WANTED! 2006 yellow special edition plastics
Atomic Monkey replied to sprayed93gt's topic in Wanted
I got a set of yellow fronts and rears uncut from a '97, got the red rad cover too. They were on my quad when I got it, they had been rattle canned black, but the guy I got it from stripped all the paint off. If you're interested, shoot me a pm -
You will notice the difference with the newer master simply because of the amount fluid dispacement. When I originally switched from stock to the 450 master, it was from an '07, and I did it just to get the brake light switch and there was no difference in the way the brakes felt.
I Feel the need to give credit where due... Sleeper06 and Lane, thank you for the clues with port timing. Especially Lane from Driveline Performance that worked with me on the timings for the 11882 pistons. A shoutout to Bansheehp for the domes... good cut and spot on for compression with being fed only measurments. CamATV for his spotless "Pro-Mod" on the trans... even all pumped I get the gear... up or down! Mull Engineering for getting us through a rough spot, Brandon pulls through and is a "fountain" of information (honestly I'm very impressed with Brandon.... he knows too much about everything!), 87sheerips for the SLP pipes! F.A.S.T. Racing, they have the parts! I know this is controversial... but Ray minkia38@gmail.com supplied the pistons and a few other parts with no issues. I hope the pistons catch on! To the individuals on the HQ: "Abe" is an excellent seller, got my dual piston front calipers from him! So is the "Mailman", got my rebuilt rear shock from him! The "springer" gave me an awesome deal on a +4 LSR swingarm and axle! "Sick421" got me a nice set of works shocks for the frontend, thanks... they're better than what I expected! "fox_forma" for the carbs! And "Burke" for the Clark tank and front plastic! I only wish I could contribute more!
- 193 replies
- cylinder porting
- (and 3 more)
Almost a year later as stuff was being deleted, I came across the video we took on the first start and decided to link it here,https://www.youtube.com/watch?v=vijPvtwVW_A
- 193 replies
- cylinder porting
- (and 3 more)
What I would do is find a steering wheel puller and then drill and tap bolt holes as close as possible to the inside of the hub on the flywheel. Might be able to reuse the flywheel using this method as it won't flex the steel the magnets are mounted to. The issue with the flywheel moving to the one side is probably because its climbing the bevel gears on the PTO side. The amount of walk is most likely thrust load related wear on the crank bearings.
1990 banshee bogs down when you hit gas.
Atomic Monkey replied to shee_rider350's topic in Banshee Repairs and Mods
What other mods, and list what isn't OEM. -
What kinda shape you expecting??? I have some tenderly used Pro Circuits.... na, all I gots to say is they function, but they be ugly U-G-L-Y. As a selling point, one pipe was steam cleaned on the inside! :-)
I like to keep it simple and try not hacking the stock stuff. I kept all my DC circuits separate. Ran an extra wire for the floated ground. Jumped into the light switch wiring at the connector, and ran seperate grounds for all the DC coming back to a small battery. I've heard of people having problems with grounding to the frame etc... In my case especially since I'm still running an AC circuit as well as DC.
Sounds good, I'll get the bearings dropped out and post up a couple pics of that crack in the next day or so.
What would you want for them? Is there a good kick start spring? That's what started all this. Anyways, looks like that broken piece of spring made it through the gears at least once.Also, might be able to salvage the case. Need to pull the bearing to see where the crack is... hoping its "superficial"
Where's the best spot to tie the front reservoirs to the frame with stock plastics?
