2strokenick
About 2strokenick
  • Birthday 08/24/1994
    Fort lauderdale
  • Interests
    bikes bikes bikes
    5 mil banshee with 35mm carbs , boost bottle ,hot rod crank, drag ported stock cylinders
2strokenick's Achievements
  1. i had the same rod but now i changed the pistons and the cylinders the old cylinders wasnt ported the new ones i have is ported
  2. when the 5 mil was running it was running good but it had a bog
  3. i just wanted to know if i need to keep running a spacer plate that all
  4. i dont remember one was like 130 the other one was like 160
  5. so i bought new cylinders, bored them over,bought new pistons , new gaskets , and the cylinders came drag ported the cylinders came off of a 5mil banshee so i know its going to work just fine
  6. the 2 cylinders had different compression thats why the mike ran kinda weird then one of my pistons was black and the other one has a black spot on it and it looked like it was burning a hole in the piston
  7. i did nothing to it i took it apart because it was bogging like at half throttle but if u let off the gas and hit it again it would reach max power then come to find out the bolts wasn't tight and i didn't have the compression to run 110 race gass
  8. why would i send it out when i already have a mechanic locally that builds banshees for a living
  9. athena cylinders are the same as stock cylinders the only difference is the bore and athena cylinders have a triple exhaust port stock ones dont i was running a 5mil with unported athena cylinder and the bike ran fine it was just due to the stupid previous owner that didnt tighten all the bolts up and caused it to have a air leek and caused it to loose compression and it didnt have enough compression to run race gas all im doing new is changeing the cylinders and pistons i dont see the big deal im still useing the athena head and domes with my stock cylinder
  10. ive had this bike for like a week now and when i rode it it was just fine it just has a lil hesitation it didnt want to open up so i took the motor apart and found out that the athena cylinders that i had on there had a air leek and didnt have the compresson to run 110 gas so it messed the cylinder up real bad so this is what i did i bought new cylinders that been drag ported for a 5mil this new cylinders i had came off of a 5mil bike so i know the set up i have is going to work i bought was long rod pistons because i have a long rod crank and i have a ported cylinder so i know that the ports are going to match up all my question was if i had to run a spacer plate still and i got intouch with kan power sports and told them the set up i had and he told me i would be fine to run what i have
  11. ive already had a mechanic look at my bike its a 5mm long rod crank
  12. my stock cylinders are drag ported already and i have a long rod crank in my bike do i still need the spacer plate ? or can i get rid of it? i just bought wsm long rod pistons for my bike
  13. i bought the bike already built as a 5mm i tore it apart and found out the previous builder didnt know what the fuck he was doing they didnt tighten up all the bolts to the head and cylinders and they told me to run 110 gas in it so it got so hot it messed the inside of my cylinders up so i traded my big bore athena cylinders for stock cylinders that been drag ported and has a 68mm sleeve in it. so i seen on ebay there selling 68mm athena gaskets but in the description it said THESE GASKETS WILL NOT WORK ON STOCK CYLINDERS so now im kinda lost what kinda gaskets do i use?
  14. im currently building a 5 mill with stock cylinders ported and has a big bore 68mm sleeve there is a spacer kit in it so my question is what kind of base gaskets to i have to buy ? and where can i buy them p.s i had athena cylinders on the bike before same 68mm bore
