fixitrod
    2
Everything posted by fixitrod
  1. 35mm pwk's or 34mm mikunis or 34mm pjs. You will not be sorry. I have a 4mil stroker and I couldn't believe the difference from 28mm flats to the 35mm pwks. I gained all the way around. I believe Banchetta had the same experience.
  2. Do this and your problem will be solved.... http://kuoi.asui.uidaho.edu/~john/tips.html
  3. Yep. I bought di-electric grease in a tube similar to rtv sealent. I use it on every connection and I love the water.
  4. OH Okay, have you put di-electric grease in your spark plug boots, coil wires and all connectors? Oh, and I'm going to assume that you eliminated the parking brake switch.... But you know what happens when I assume. Just another thought.
  5. Yep, the x-ring supplies two points to hold the grease in. Also, it leaves a channel for grease to sit in. How much better it is... I don't know.
  6. Grand River Racing!!!! I have a ported motor from them and It's amazing. It's also a stroker.
  7. Stock banshee carbs do not like water. They just don't. Someone put clamps on the choke tube and swore that helped. I did a ton of work trying to get the stock carbs water happy and I never prevailed. I bought some 28mm flat slides and never had a problem again. Good Luck!!!!
  8. I've beat the crap out of my DID xring and it's fine. I'll be buying the same type when it's time.
  9. I'm still a little confused on the lcd monitor. Is it a pc monitor or a video monitor? Anyway, I bought one of those portable tv's with the built in dvd player. It has input jacks on the front for the kids' game systems. I just use an invertor for the game systems. Works great!! It came with a back to hand the tv between the seats. We use it in our camper too.
  10. A monitor uses 3 color leads and a signal lead. Im not sure how you'd get that to work with an rca connection.
  11. Buy my house and kill the guy who took vacation on those days already. That'd get me there.
  12. How will the rings seat properly if you don't hone it?
  13. I will not be there. Damnit !!!
  14. Check your rear sprocket. The teeth may be bent forward. If your axle isn't aligned straight or your chain was loose, that can happen.
  15. I'm still not sure. I have to say it's not looking good and I'm not making excuses. I have found a house but haven't sold mine yet. I have to swing an extra $1200 for the next couple months and have no idea how I'm going to do it. If my house sells and all goes well... I WILL BE THERE.... but until then.... probably not. It's coming down to both time (moving date) and money. I'm doing what I can here.
  16. I have heard tyson makes good motors.
  17. It'll get better. I just need to find time to get that jetting right. Once I get it it will be fine. I have not had it jetted just right since I've had it... at least for indiana. I had it really close at dumont.
  18. The other blonde lady says Wow it's Huge! in like the same pose as the other two. 299 is the high I got.
  19. Lol, have you ever seen those little weights they use to balance a tire.
  20. Yeah, I got the black haired chick in the same pose. But, she say Ding Dong!
  21. Well, it could be the manager of the stores too.
