bigweav81
    7
Everything posted by bigweav81
  1. I couldn't see how anyone could tell if a crank is trued, and welded by looking at it while being mounted in cases. I guess you could remove your waterpump, and primary gear.......cut/ rip your seal out, and look....but then your splitting your cases anyways. Maybe I'm wrong. You can tell if your crank is stock by the rods.#
  2. I don't know about bug power lol.......but that's a lot of compression on a stock crank!
  3. If your crank isn't trued, and welded. Then your more then likely flirting with disaster running 17cc domes.
  4. ^^^They always use the old......it needs rejetted trick. Sent from your mammy house
  5. Overheating, you need to figure out why. Sent from your mammy house
  6. ^^^Agreed, but it's necessary. If you leakdown while assembly I think it eliminates a majority of extra work involved trying to do it once everything is assembled. Sent from your mammy house
  7. ^^^this, your pilot should be plenty. Do the leakdown test.....if not your more then likely chasing your own tail! I think people avoid it because they fear the worse. Sent from your mammy house
  8. I figured those were outer crank bearings. Sent from your mammy house
  9. Pm atomic monkey. Sent from your mammy house
  10. ^^^^That's it. Sent from your mammy house
  11. I got ya, they do look sweet though. Sent from your mammy house
  12. Sheerider11 posted a link when I was looking, but by that time I went with another helicoil. It will fail again I'm guessing go with inserts. The thread I'm talking about was cylinder stud removal, and repair. Google it, and you should find it. Then go kick whoever did that square in the dick lol. Sent from your mammy house
  13. You going to run shaws on a trail bike? Sent from your mammy house
  14. Order some inserts, and m8x1.25 studs.....I think that's the stud size anyway. Changed some over a month ago, but I have short term memory. Sent from your mammy house
  15. Ohh fuck lol. Sent from your mammy house
  16. Can't see pic are they bolts or what? Sent from your mammy house
  17. Yeah..........maybe they had some stripped studs, and cranked some bolts down in there. Sent from your mammy house
  18. Are they bolts, or capped nuts? Sent from your mammy house
  19. He was a big 4 year old. Sent from your mammy house
  20. If you have stock carbs make sure your cross over/ choke tube between carbs is connected Sent from your mammy house
