JTmachining
HQ Site Sponsor!
    84
Everything posted by JTmachining
  1. Ur a dumb fuck. I did not ask u a question. Post up pics of ur Banshee here or GTFO
  2. So a 7075 40mm drilled axle is or isn’t strong enough and lighter than a solid one....lmao GTFO with useless info for BHQ
  3. Zilla and RU are one and the same
  4. He’s the only one of the dummy’s who’s putting it to application as it applies here. The other dumbfuck is just posting general info pertaining to one diameter without application as it applies here on BHQ. Copy and paste dumbfucks
  5. This is where peeps get lost from paper to hands on. I think it’s going over peeps heads on design and application. I’ll not post on this no mo
  6. Stupid simple. Also for the wanna be Google smart peeps stock axle size and material is not used on the 7075 gun drilled axles for drag racing. Guess what....the 7075 gun drilled axles are lighter than stock, stronger, and work in real world. Peeps need to look at design and application before posting shit that doesn’t pertain
  7. JFC. Round tube is only one shape. GTFO Zilla
  8. I’m def not either but in tube form the process to make the tube makes it not as good of a choice due to less strength etc compared to solid material
  9. How did I know Zilla gona copy n paste. Multiple dimensions ads a dimension and can increase strength in certain designs/applications. Real world experience talk
  10. One dimension vs multi dimensions. Now wat up
  11. Peeps only give props to a win. It doesn’t matter cyl or size. Go big and fuck stock cyls
  12. OP is doing a drag bike. Serval isn’t a good option vs others
  13. Who did the trans work? How u using Banshee...300ft dirt, dunes,...?
  14. Let a legit builder do it all. I’ve had a 7mm stock cyl motor and a 68 bore cub both with LEDs. Stock cylinders take work to make powa and $. Save ur $ and do a cub or bigger
  15. Peeps FFS. Think about dynamic loads if u gona do fab work. Upper steering stem mount area is one of the weakest locations on frame. Start there
  16. Stock frame needs to have sections cut out and chromoly added
