gusto
    46
Everything posted by gusto
  1. If your motor is not a cub, and under 400cc it won’t really matter
  2. I believe the OD of the FMF stingers are smaller than the CPI. I think CPI stingers are 1 1/8 OD……if I’m remembering correctly
  3. Thats going to require a professional to look at it and probably plating. Im no expert though, if it were mine id reach out to Millenium plating and ask them
  4. Bring it to shop. It might be enough to snag a ring. Also, you might need plating repair. This is something that can easily be fixed but by a professional
  5. The shop cant get the bike started after this? Are they fixing it for you? Do you have spark?
  6. if you have fmf silencers send me a PM
  7. If your strictly drag racing cub for sure. Riding with occasional racing for sure serval. Servals run best with cpi shearers and snipers it seems as far as max power goes.
  8. The Chinese carbs always cause problems . beat bang for the buck is a port job to match your pipes, new reeds v force or pyramid. No need for a cool head, shave your stock head. You’ll notice big gains. if you have more money get a striker crank for an extra 7-10 hp
  9. Buy used stock cylinders and have them ported for the crank and your domes cut for the crank. No space required. youll need stroker pistons stock cylinders cut domes for stroke aftermarket head. have your crank inspected and send to a banshee builder there are a bunch.
  10. Your being asked if you used 795 (stoker pistons) or 513 (stock stroke).
  11. Looking for a brake light era rear caliper, master cylinder, brake hose, switch anything else that goes with it. Thanks Need it shipped to Canada
  12. You need to do a DC conversion. Google it
  13. FAST is hands down my fav sponsor, always has what you need and always gives great advice
  14. What did Alba say about your take and an arms? Offer return?
  15. Clutch for sure. Pancake bearing, high flow impeller, shifting mods, and new eccentric screw. your wanting a striker crank? Driveline cylinder kit is nice for the money. keep your crank and go 392 also. So many options for you.
  16. Still have your stock carbs? They’ll work nice. If not pwk 28 or 33
  17. The answer is calling Noss, he will set you up https://nossmachine.com/domes-inserts/
  18. Nothing. Bonzi garage on YouTube uses them, he thinks t5s produce more power. Out of all the pipes still being manufactured for a decent price I’d go SLP for low rpm high torque, PC for mid range, shearer for top end. Where do you want your power?
  19. Nice pipe, low to midranges focused, never ran them but from what I found on dyno sheets don’t produce as much mid range power as pro circuits. If your looking for mid range pipes FMF fattys are nice and usually found pretty easily
  20. Stator failure could be the cause of some of your problems. Buy OEM. DC conversion with JL Engineering battery pack is a nice upgrade, don’t exceed 70 watts. someone in the wanted section was looking to trade big bore shearers for small bore, I’d jump at it if they’re still available
  21. Good luck with the Paul turners, hard to find them in good shape anymore. if your looking for that mid range hit look hard at Pro Circuits, and you can still buy new.
