uman1030
    3
Everything posted by uman1030
  1. Some one made the hole slightly too large when drilling/tapping for idle screws not saying reg old white teflon tape wont work but supposedly gasoline dissolves it id use the yellow that is for natural gas, hydraulics and other petrol-based applications..
  2. doubt you will get a reply OP has 2 posts and hasn't been on since July 3 which was his reply to a question in this add. he did leave a contact number tho which may be more helpful (816) 225-7012 but id assume its sold, never hurts to check tho.
  3. most likely +2 wider +1 forward seems to be the most common extended a arms. Could wrong obviously i believe stock is 13 1/4 so if its +2 then you would need 15 1/4 this is not including tie rod ends cant you just measure the existing one for replacement size? Edit** apparently the tierod i measured was already a +2
  4. Ah, didn't realize initial price that shipping wasn't included since it didnt say so. doesn't matter to me much regardless i live like 20 miles from you...tossed up the idea of buying them for my 89 which i am turning into a dragster but then i broke my cases on my trail bike and had to buy a new set of cases lol.
  5. Been a while since ive messed with these. Think it was clockwise to raise idle, counter to lower I can check on a set I have laying in my garage in a bit.
  6. plus $26 for shipping so basically the same price they were offered here. i almost inquired about them but ive kinda got my hands full (and wallet) building this trail bike atm...
  7. may have to send a text or call for a reply he hasn't logged into to site since the post.
  8. Found a set Hazzaard's hooking me up.
  9. Looking for a set of good cases, no chain wacks LMK what ya got.
  10. These are also for a serval cub trail bike Little of everything the track I ride is basically an MX track with diffrent areas some open fields, two tracks and wooded trails but also want to hit some dunes this summer up at silver lake dunes.
  11. Its for a new build I have t5s which I won't be installing on this build.
  12. Wondering how big of a difference in these pipes for a 421 on pump gas. Trying to make a decision asap to either buy a used set of rockets or add to my order at FAST for some shearers since I hear a good used set us hard to find
  13. No its not normal but as to why its hard to say without more info. If it dies have bigger carbs it could be they are too big for a stock motor. Like I said tho hard to say without more info
  14. Measure inside bore of the carburetor engine side. Could also post a pic of carbs and we could at least tell you if they are stock
  15. Since you already have these questions you can answer some of them yourself with a compression check and by looking at what jets you have and checking the sync on the carbs. Report back with your findings and some one could probably tell you what you need to know then.
  16. http://bansheehq.com/forums/index.php?showtopic=172306&p=1556095
  17. Stock filter. And thats a much worse design then the pro flow adapter mentioned above which is much more secure . And as fir clamps. You use the same ones so not sure what he means about the k&n clamps loosening. Clamps are clamps for the most part
  18. ill make note of this, Jeff at fast is taking care of me and cutting domes etc. I have faith he will set me up well.
  19. ya i just looked and they havnt even logged in since my message so i cant fault them for not replying. Pretty sure ive found the set i want already tho just waiting for him to take them off and give me the paypal info etc.
  20. Thought about it but i had sent them a pm about some other questions a few weeks ago and didnt even get a reply back.
  21. ya most likely what will happen spoke with him yesterday while ordering alot of other parts and this was something we talked about but i figured id check here first but most likely i will just order a set. was contemplating a set of rockets that a member has so i took a look at the dyno charts listed for the 10mm serval and i was curious what the rockets would do for a 421 serval with slighly less hp. any one have an opinion on these rockets for a 421 serval as opposed to some shearer's?
  22. Looking for a set of Shearer small bore small flange inframes for a 421 serval LMK what ya got
  23. ya taking others advice and not using airbox, ordered pods as well as a plethora of other stuff.
