Denny2424
    2001 yamaha banshee white and blue
Denny2424's Achievements
  1. So the cylinder ports are lowered the same for a short rod and long rod 4mm crank? I was just thinking of going with the stock stroke because I have one already.
  2. Hi I have a set of ported cylinders that were on a short rod 4 mill motor. The crank is no good. Can I run the cylinders on a stock stroke crank? I know the port timing is different on the long rod crank, but not sure if it is on the short rod crank. Thanks for any info.
  3. I have a stock one for 100 plus shipping
  4. Kan power sports sells the clear radiator hose. Check out his website or Facebook page.
  5. Can I run 21-6-10 on my stock front banshee rims?
  6. Do you still have a cdi relocation bracket?
  7. Can I run 21-6-10 tires on my stock front banshee rims?
  8. From the back the camber looks like it's out. Like the top of the tires are pointing in opposite directions. Sent from my SM-N900T using Tapatalk
  9. Wow! That's in bad shape. Front end looks out of wack also. Sent from my SM-N900T using Tapatalk
  10. Do you still have them? Sent from my SM-N900T using Tapatalk
  11. Awesome. Thanks guys Sent from my SM-N900T using Tapatalk
  12. Anyone know who sells motor stands? Sent from my SM-N900T using Tapatalk
  13. 75 shipped? Sent from my SM-N900T using Tapatalk
