kedge82
About kedge82
  • Birthday 04/08/1982
    cedar rapids,iowa
  • Interests
    quads,xbox,green trees,women
    2001 .06 over stock carbon fiber reeds pivot works crank wisco pistons k&n air filters after market box with no lid itp hole shots sst fmf exhausht and silencers +2 lonestar axel
kedge82's Achievements
HQ Soldier
HQ Soldier (2/5)
2
  1. what color wire would it be most of that shit has been deleted from bike but i guess it could be shorting out? idk
  2. so last week shee was running funny. popping and shit out of left cylinder when i killed it it the left pipe would smoke for about a minute while off. took home did some looking and testing founf pick up coil was only at 89 ohms when book says 94 to 140 so i ordered a new one put in then couldnt get to start. did some more searching found one of the wires i soldered broke, so fixed that and still nothing. my ignition coil is an oem that i bought last summer, but i have had probleoms checking it not getting readings or am just to stupid to do it right, stator test good. got it running after an hour or two. at idle both pistons where firing. as soon as i break about 3k rpms left side quits completly. and right has no power and lacks the ability to barley make it back to the garage. i am in prosses of checking pick up coil gap but there is really no adjustment for it. what if any are you suggestions. i was maybe thinking the cdi finally went out but i dont know there siigns and know they are untestable.
  3. just bought hinsons but dont come with primary gear so if you have one that you want to get rid of or even a broken oem clutch basket hit me up. oem or straight cut if straight cut would also need kicker stright cut if the price is right thanks
  4. ok so i just bought some hinson clutches but it dosent come with the gear on the back. what gear is neesded for these if not oem and how are they installed. hte oem clutches look as if the gear is on studs, or something simalar they dont lok removeable. so my question what gear do i nessd to buy and how is it applied to htese clutches thanks
  5. whats up on the stock cylinders and head i havent seen anything saying they have been sold? what bore are they?
  6. im going to say 240 or 250 but start high work down maybe 260 i see sea level varys from 0- 1800 adjustment need made evry 1000ft fyi
  7. the boost bottles are junk like he said they just tear up intake boots in two years i went through 3 sets, ditched it got oem crossover and there was literally no differnce in proformance. of course the ppl selling them are going to give all kinds of good info on them thats there business. as for jetting you allways want to start rich and work down to top profrormance. with 34mm witch imo is a lil big for stock motor. i would love to give you a starting point but my knowledge is limited to stock carbs. if you had them i would say start at 300 but you dont and with larger carbs i dont know where to start. have you ran it at all yet? if so how did it run? was there lag through any gear or certain part of the throttle accelaration? what jets do you have in? if youve ran it and it dosent fall on its face through gears or the power band that means your not rich but could also be bad because you could be lean witch would obviously be detrimental in the life of your shee. jetting is really a trail and error prosess. which can become quite time consuming, but a most. someone with 34mm will chime in soon to get you a good starting point
  8. uman im going to say you were correct at 280- 290 but with lid off. i think 280 with lid on would be to rich i would think lid on 260-270 but thats my opinion
  9. what is your elevation? what temp do you ride in? your air box, stock with lod no lid no box w/pods aftermarket box for good ifnfromation from us we need to know specifics
  10. i would say full race gas 110 at least 310 good starting point
  11. fmf sst's have built in arrestors and are approved for forest riding but you must buy set other silencers do not work with them propely and they sound desent it think anyway
  12. im tto dumb to know better
