alpine04
About alpine04
- Birthday 12/15/1992
Gender
My Banshee (optional)
white and red 04 banshee 4 mill .030 play/ dune port by F.A.S.T Toomey T5
alpine04's Achievements
okay man thanks
- 37 replies
im building a 4 mill and was wondering where i should send my cylinders for porting, is that Grand River Racing spot a good spot? Looking for a aggressive trail/dune port or something like that
- 37 replies
yeah but i thought that they made pistions for the 4 mill to make up for that? im not gonna try and be complicated if i need to get it reported thats what im going to do. and where would you guys recommend to buy a cool head and domes from ? and what size domes for pump gas?
no the porting was just for the stock crank motor then. do you think i should send them away to get re-ported?
yeah i forgot to mention the cylenders i have now already has a trail port, and i was gonna go with the 4 mill pistons and the domes instead of the spacer plate. good idea or no?
my hotrods 4 mill 115 long rod crank just came in so im currently in the prosses of putting that in, just waiting on some seals and stuff, but i have a friend thats talking alot of shit and thinks his stock piped and jetted crf450r is the most powerful bike there ever was. and everybody in town is sick of it. so i need to be able to walk all over him on pump gas. im gonna get some v force 4s, adjustable timing plate and a cool head, and i already have T5s. how do you guys think i will do with this set up? let me know if theres anything else i should do or change
lol okay..i searched it and alot of people were saying atf type f
clutch is slipping pretty bad right there now so i ordered a new one but i was just wondering what kind of fluid you guys would recommend to run? thanks.
i cant get any pressure in my rear breaks no matter how much i bleed them, does this mean my brake cylinder is gone? should i just buy a new one or i saw a rebuild kit before for them?
Sounds good guys! Thanks
- 6 replies
- 4 mill stroker
- crank
(and 2 more)
Tagged with:
so my banshee blew up, shattered the skirt off the right piston.so while i have it apart im going to build up a 4 mill. was just wondering if theres anything important i should know besides getting a spacer plate or domes and having my cylinders ported for it. and i was wondering where the best place to order my crank from would be? thanks
- 6 replies
- 4 mill stroker
- crank
(and 2 more)
Tagged with:
well yes lol of course
- 6 replies
- compression
- crank
(and 4 more)
Tagged with:
okay because it was running fine when i parked it then i started it up the next morning and thats what happened. i will try that and see what happens
- 6 replies
- compression
- crank
(and 4 more)
Tagged with:
ok so my banshee is workin like crap, its having trouble getting up to rpm but when it does everything sounds good and snappy. but im smoking out of my right pipe and my right stinger only gets a little warm (i can grab it and hold it with my hand) where my left is nice aand hot. never did a compression test on it yet but im assuming thats the problem. im just wondering what the deal on the crank seal is i see people talking about. hope thats not my problem. fresh plugs and lots of fire stock banshee but toomey t5s, stock pilot, 280 main, air fuel screw 1.5 turns out, no air box cover, uni filter
- 6 replies
- compression
- crank
(and 4 more)
Tagged with:
