Juss11
Everything posted by Juss11
  1. I sent my stuff to Keven (herrjuggs) for a 4mill dune port/bore etc. Had everthing back in 2 weeks. I have never had Jeff do any engine work, but I have bought a lot of parts from him & he sends fast!! Both are great guys.
  2. I will order one from FAST on Monday. Thanks guys
  3. I got mine from fast, great guy to deal with!
  4. Never mind I got a set of 28mm pwk on ebay for $200. I really wanted some 35mm but these came with new K&N pods with outer wears & throttle cables
  5. Whats the best intake for 33-35mm carbs? I know some mover the left carb up some, to avoid hitting the clutch actuator. Also if you have one you want to sell let me know. Thanks
  6. Im looking for some PWK carbs for my build 28-35MM. Also need intake & K&N pods
  7. Do you still have these carbs and pods? Why did you change the idle screws? Can the stock screws be replaced?
  8. Damn just what I am looking for. I always miss a good deal!
  9. Another guy on here has like 75 sets of these OKO 30mm carbs new in the box. He is asking $150 Shipped per set, just letting you know
  10. Your port timing is going to be off running a 4 mill crank without porting your cylinders. I guess you can run a spacer plate
  11. I was going to ask in the other form, why you went with a 4mill crank but your cylinders arnt ported for it?
  12. I was at Pismo labor day weekend & saw a General Lee Banshee heading into the dunes down by pole 6
  13. I got a set but have not ran them yet
  14. Kevin(herjuggs), charged me about $350 for my 4mill dune/play port.. Having your cylinders honed, has nothing to do with porting. When you port you have the intakes,transfers,exhast etc opend up bigger, for more air/fuel. Im guessing why you only had them honed, is b/c 0.80 is it on your cylinders and cant be bored anymore! Im no fan of honing cylinders and running new pistons. I've never had much luck with that. Id look for some stock bore cylinders and have them bored & ported, not yours.
  15. He has 2 neg feedbacks. Not so bad, cause people leave neg for some stupid shit! One guy left me a neg once cause he was not home when fedex came by & he had to wait till Monday to get the item, cause it was a 3 day weekend. Just saying!
  16. Im going to get some 28mm PWKS, just wondering if my K&Ns from my stock 26MM will fit the 28s?
  17. Will K&N stock pods fit 28mm carbs PWKS?
  18. Its been along time since I messed with stock banshee carbs, but from what I remember one of the float bowls has a little jet in it for the carb with the choke. If its on the wrong side it will run like shit. Try searching in the forms
  19. I mostly use the rear brakes, same if on my RMZ450
