Juss11
Everything posted by Juss11
  1. I'm going to see how these are and go from there.
  2. http://www.cascadeinnovations.net/store/store_View.cfm?STORE_AREA_ID=13&store_dept_id=140 Try this link
  3. These are cascades.. No sorry have not finished my build yet to test them.
  4. Cascade has a nice set with stock location mounts. Lights are trail tech. They also just sell the mounts if you want to run diff lights.
  5. Im 40 & my 71 yr old dad still kicks ass on his Banshee in the dunes. He says they dont know my age till I take off my helmet. lol
  6. I have to look and see what needles they are. So I do have some 158 mains, I will start with those. Thanks for the great advice
  7. So just looking for ideas? I have a 4mill dune port with long rod. Im going to be running 28mm PWKs,v4 reeds,t5,custom cut doms for pump gas & k&n pods, at sea level. So Kevin at herjuggs said to start with a 155/55 does that sound about right? Also what position should my needle jet be set at? I forgot to ask him.
  8. Try tilting your quad on its side to see if it will slide out, Don't think its possible for the rod to slip past the actuator
  9. Have not tested them yet. Im in the middle of putting my bike back together. Waiitng on some carb parts etc..
  10. Thanks for the great info. Got this kit installed today & they look great. Ya had to cut some of the stock mounts as you stated..
  11. No complains from my driveline clutch, but FAST stuff is great also
  12. Should be no up & down play, a little side to side is ok.
  13. I just installed new bearings and oil seals in my carrier. Once back together If i turn axel nut even hand tight the axel will not turn. I know its togetther right. Tore it a part checked it out again, took the spacer out put it back together problem solved. Forsome reason the bearings are pushing up against the spacer. Has anyone had this problem before. Can I run it without the spacer? Bearings and seals are OEM Yamaha.
  14. I always have better luck getting a hold of Kevin like after lunch time. He is in Cali, so make sure its like 1pm or so his time
  15. This is true.. I took my little girl out yesterday so she could ride her TRX90. This guy pull up on a 2000 Banshee with Full Elca shocks,roll desighn A-Arms. T5 exhaust, cool head, PWK35 carbs K&N pods, you name it it had it. This Banshee was just rebuilt from ground up, even frame was PC. Guy told me he just bought it for 2K. I was like jeez what a smoking deal!
  16. Are the trail tech lights with cascade stock location, billet mounts, pretty good? I see cascade has this kit for $189.
  17. Dude, I don't get you. You just said in another form, you just built your motor with a new 4mil crank! Now your wanting this guy to hold his for you till next month? Unreal!
  18. I seen a 4mil set up for $600 in the 4 sale form
