hoppedupandcutdown
    73
Everything posted by hoppedupandcutdown
  1. or pull the tank off the bike, hold the vent hose up so it and the petcock are the highest point, block it up on the floor like that. but to answer your question, no it won't ruin your engine. The off valve is for transporting the bike so the carbs don't overflow. even if they do it will still just run on the floor. assuming your seats are good you will be fine. But really, grab a can and drain it. You should have a Banshee only gas can anyway.
  2. All this Chevy C/10 talk, here's my barn find. Wasn't hard to find, it's in my barn...I haven't driven it since '96, chopped to the top in '91, don't even know how long I've owned it.
  3. did you ground the RED/BLACK wire when you deleted the key switch?
  4. Well you're no fun. You're not supposed to ask until after you have it all jacked up so we all can ridicule you. HaHaHa, welcome to BHQ
  5. broken wire inside insulation or right at a pin, causing poor connection. Ohms check and wiggle at the same time.
  6. start with new plugs. An easy way to tell which side isn't firing is which pipe isn't warming up. not so sure your "dry" might not be the problem side. There's a long list of things that go wrong from storage, from stuck needles and seats to rats nest in the pipes.
  7. http://bansheehq.com/pdf/Yamaha%20Banshee%20Service%20Manual.pdf Easier to buy a Clymers manual and have the book in front of you.
  8. Yes, they only go the correct way when in the correct carb. should also have dots that line up in the windows to help sync.
  9. cutout in the green circle goes filter side
  10. You had something build a nest in your pipe. remove it and rod it out.
  11. I had them put a seal head in a front YFZ450 shock, SUPER fast turn around time and Courtney was great to deal with over the phone. Thanks for the fantastic service, you saved my annual family outing at the dunes for Easter weekend.
  12. http://www.vxb.com/page/bearings/PROD/NEEDEL_ROLLER/Kit12307
  13. Evaporust will do a great job, soda blasting won't cut rust.
  14. If you've got a hole big enough to suck in enough water to cause problems, then you got big problems.
  15. How much Plastidip did it take to do the Fullbores inside and out? And how many coats?
  16. site sponsor and great people to deal with. http://www.ebay.com/itm/Yamaha-Banshee-V-Force-4-Reeds-YFZ350-RZ350-VFORCE4-NEW-100-FEEDBACK-FREE-KOOZIE-/330993367963?pt=Motors_ATV_Parts_Accessories&hash=item4d10bdfb9b&vxp=mtr
  17. Thanks for the offer. I sent the one to BVC racing, they should get it tomorrow. I'll wait and see what they say.
  18. From the nipple under the radiator cap to the bottom of the bottle. From the top off the bottle up front up the steering stem and down (just left open)
  19. To run - the red/black wire to ground, the white/black cannot be grounded.
  20. Depends on exactly what you are after...use this http://www.bansheehq.com/bansheehq-sponsors/ I use these guys alot... http://www.farmandsandtoys.com/
