hoppedupandcutdown
    73
Everything posted by hoppedupandcutdown
  1. Banshee's are washed and new chrome spindles installed on the orange one! IS EVERYBODY ELSE READY?
  2. choke doesn't work? bowl on wrong side, for starters
  3. What is the 10th digit in your V.I.N.? I'm curious if it is really a 1999, as you stated in another thread.
  4. what year? actually never mind that, look to see if you have a green/yellow coming out of the CDI, if so cut and tape off.
  5. David's new theme song Try and get that outta your heads, HaHa
  6. That's the choke crossover tube. But the choke is actually a fuel enricher, when you pull the knob out on the left carb, it sucks up fuel and passes it to the other carb via that hose. When left off you have two large air leaks. Enough your quad will not kick start. You could probably drag it and bump start it but it will run bad and melt down from a lean condition.
  7. Well, it will NOT start without that hose installed.
  8. Is this black hose installed between the 2 carbs?
  9. Get one for an import car, as long as it fits the radiator neck, it'll work. For the cooling system pressure test.
  10. what's it doing that makes you think it needs different size jets?
  11. Who mixes by the tank, not a 5 gal cans worth or what not?
  12. Well I'd say you got it figured. That white/black is the kill wire when grounded to anything. Nothing beats a new wire harness when your old one is a cobbled up mess.
  13. Welcome back to BHQ FB, Schowzy! You can hang around here too. Howz things by the way?
  14. Or an "only me" album on Facebook and then copy image and paste here. That's if you gots the Facebook
  15. Do not replace those o-ring cushions, no need for them. It must have 7 fiber-friction plates It must have 6 steel plates
