hoppedupandcutdown
    73
Everything posted by hoppedupandcutdown
  1. And test with both plugs out, wide open throttle, kick until the needle stops climbing.
  2. I was going by the swell for the brake hub, (lack of) - Nick posted a pic in this guys other thread. But I actually DGAF
  3. Post some pics. Where are you from? Welcome to BHQ!
  4. Could be the inner race of whats left of the bearing. Very hard to tell from your pics. Not a factory Banshee axle. Try to take clearer and more pics of everything you have. No way to be much help with what we've seen so far.
  5. Correction, Hobart will do the welding. DDQ will simply master the controls. Welcome to the BHQ coops03!
  6. Come on! We'll have more than enough room for you...Spots 1 and 2 LSPS SandCity
  7. You'll need to post some pics or this will go nowhere fast. The rotor and it's hub have to go on the axle before it is slid thru the carrier.
  8. how did you slide the rotor on if you can't get the axle out of the carrier?
  9. I've got 3 weekends already reserved before the Spring ride, I'll have the sand plumb worn out before I see you guys in the Fall.
  10. http://www.bansheehq.com/forums/index.php?/topic/105900-windowed-clutch-cover/
  11. If you are referring to the 6 bolts that hold on the pressure plate, by the part number they are 6mm on a Banshee. 90159-06016-00
  12. Why so far out? Have you tried them in a turn or 2 further to give it more fuel?
  13. Copied this right from their website. If you had your own tooling you could have one tomorrow. I'm still going with there tooling is lost or damaged. Commercial Services- Specialzing in Hi-Definition, Deep Draw Vaccuum-Thermoforming - Extremely Fast Turnaround Time (often same day) with customer supplied tool or pattern - Most experience in the industry forming High-gloss TPO plastic - IF YOU HAVE A PRODUCT THAT NEEDS TPO PARTS " WE ARE YOUR SHOP" - Fullbore specializes in Trade Show Booth & Exhibit components as well as P.O.P. Displays Materials formed : - High-Gloss TPO - Utility TPO - ABS - Styrene - PP - PE - PETG - Acrylic - Polycarbonate - TPR - Softtouch - Softfeel - Ultratuf22 "if it can be formed we can do it" - 3 forming machines to fit your needs up to 5' x 10' x 30" draw - CNC Pattern and Tooling capabilities on a 5'x10' x 36"Z Router - Complete tooling shop for start-up projects - Mold repair and maintenance services - Negative Draft (Die-lock) we can help - Low cost patterns for Prototypes - MANUFACTURERS/ SUPPLIERS If your current ABS parts are cracking, fading, discoloring or chalking we can eliminate all of this by transitioning you into high gloss or utility TPO parts for less than you think
  14. Pickup coil should be 94-140 Ohms (white/red to white/green wire)
  15. Well, what'd ya get Sheerider? Also in the market for a lightweight helmet
  16. Well, telling people "next month" for 2 years is so truthful.
  17. I could see if the Banshee tooling was damaged in the fire. To re-tool would be in excess of $20,000. They would have to sell $40,000 worth of Banshee hoods just to break even. Now that would be an understandable excuse.
  18. I'm telling ya, That's what they told me over 4 years ago! Makes zero sense.
