hoppedupandcutdown
    73
Everything posted by hoppedupandcutdown
  1. So maybe your port/pipe guy should be on here asking. Since you are expecting us to give carb recommendations for a set-up with specs that you can't provide. Or maybe in a few more pages we can get all the pertinent info drug out of you if we ask the right questions?
  2. If you're certain the crankcase is NOT pressurizing the trans, then for sure the rear vent hose (under the rear most motor mount) is pinched.
  3. Almost for sure Kalin still has a white rear fender
  4. Color? Grille style? Rears full or race cut? Price? Location? Shipping? Pictures?
  5. Mine came with 12.9 grade cap screws. More better.
  6. It would be replaced by a Regulator/Rectifier, like the universal Trail Tech
  7. Yes, exactly. Make sure it is connected and bolted down tight to clean bare metal.
  8. Ryan's gonna think I'm picking on him again, but he meant regulator.
  9. copy this set-up... http://www.ebay.com/itm/Yamaha-Banshee-Blaster-Leak-Down-Kit-Fits-Stock-26mm-Carbs-As-Well-As-28mm-/172557971718?hash=item282d41b106:g:i5AAAOSw9GhYl3Sj&vxp=mtr
  10. http://www.bansheehq.com/forums/index.php?/topic/110585-leakdown-tester/ But use this, much simpler and easier http://www.homedepot.com/p/DANCO-0-15-psi-1-10-Increment-Gas-Test-Gauge-94352/100180536
  11. This, right? http://www.bansheehq.com/forums/index.php?/topic/123470-primary-gear-back-lash-number/
  12. Do the primary gears need to be replaced in matched sets? I thought i read somewhere that they are engraved paired up. Yamaha does offer them separate. Asking for a friend, my shit ain't broke.
  13. Typo, no matter what, stock Blaster is 200cc (actually 195cc)
  14. You have every right to find out where your carbs are. But - it's actually only been 7 business days. Always a good idea when ordering something desperately needed, to call and verify stock levels.
  15. Welcome, It's easy to just "copy image" from Facebook and paste here
  16. Yes, but 90% of regulator problems are because it isn't bolted down tight to a clean bare metal surface.
  17. should not read more than 16.3volts DC at 8000rpm at any lamp connection
  18. A few pounds is lot, but the money I'd spend on Evols and lose on my Elkas, maybe not enough to worry about.
  19. I have Stage 4 LT Elkas, I think they are heavy... Tyler, any idea in weight between the Elkas and Floats you had?
  20. Some will last, some won't. Seems to be a crap shoot. High or low beam wire does not matter. Having a functional stock regulator does though.
