hoppedupandcutdown
    73
Everything posted by hoppedupandcutdown
  1. Center to center. But it's easier to read from left of hole to left of hole. Or right of hole to right of hole.
  2. HaHa, LMAO, at least you're honest. JK, everyone makes mistakes.
  3. So they are actually really close to 3/32" off on every stud. How did you come up with the 1/2" - 3/4" earlier?
  4. Yes, should measure the holes straight across, IIRC Blaster has a smaller center hole so re-drilled lug holes won't work, but changing to Blaster hubs certainly will.
  5. To answer Profilact's question from the shoutbox... Have the youngster review this to become acclimated to the BHQ dune experience
  6. I've used paypal all over the world. Never a problem, they actually called me to verify a purchase just the other day. I've only ever gifted payment to Gato. Always received items in a timely matter. Just lucky I guess.
  7. Hot motor needs the throttle cracked open just a bit on start-up. Try that next time.
  8. I would hope none, but I've tried to pull start something until it was "really hot" Without that hose the motor won't be able to draw fuel, so it would be super lean. Might at least try new plugs. That hose not being there should have been your issue and putting one on, it should have started right up.
  9. How long did you try to pull start without that crossover hose to get really hot? That's a huge air leak and could have done considerable damage.
  10. We're quickly working our way down to Gas on? Gas in tank? LOL It's happened
  11. Working easy has nothing to do with being backwards. But if you marked them should be good. Are you sure you put the hose on the correct nubs on the carbs?
  12. The dot is not in the picture, the cut-out that should face the air filter is.
  13. Both, if you have one in backwards, you have them both in backwards. They only go in the wrong way in the wrong carb. The windows are both on the right sides of the carbs IIRC
  14. Either unplug it or plug the other 2 on the carbs back in.
  15. AH HA! unplug the 3 wire brain box under the left side of the tank
  16. If you can see the dots in the window at WOT you are good or
  17. All 3 of TORS plugs plugged in? Or non at all, can't be any other combination
  18. Slides in the correct carbs? Didn't change any main or pilot jets from a rebuild kit did you?
  19. Bowl with "BB" at red arrow in pic on the left carb?
