hoppedupandcutdown
    73
hoppedupandcutdown last won the day on September 13
hoppedupandcutdown had the most liked content!
About hoppedupandcutdown
  • Birthday 04/10/1963
    Milford Kansas
    yes
Recent Profile Visitors
hoppedupandcutdown's Achievements
HQ General
HQ General (4/5)
1.1k
  1. Make sure the orange and black wires attached to the spade terminals on the coil are on properly and the wire is still connected to the spade inside the insulating boot. Seen them get bumped and broken while working in the vicinity.
  2. The extended ears for the caliper mount on the spindle and the lack of countersink on the hub for the rotor bolts tells me you for sure have the early stuff.
  3. Yamaha still sells OEM carbs, that DO NOT come with the T.O.R.S boxes. RMATV has them for $301.45. Maybe you should take your own advise.
  4. Although I don't see how they can compare their straight weight to a multi weight. especially when you know "W" means "winter"
  5. Anyway, for the OP... This is from Bel-Rays website to help clarify weights of motor oil vs gear oil . "A 10W-40 motor oil’s viscosity is actually similar to the viscosity of 80W gear oil, and the viscosity of SAE 10W-30 is similar to 75W gear oil."
  6. Klotz flex drive 30 trans lube is 75w80. 75 cold 80 warm. not one or the other.
  7. usually happens when running out of fuel, or sticking slide or cable.
  8. Also, pistons in the right direction? Chock crossover tube in correctly?
  9. plugged up exhaust. Popular nesting spot when the pipes are laying about during a rebuild.
  10. forgetting the choke cross over hose can cause that.
  11. Drain hole so crap doesn't collect on top of the case and/or run into the stator area if the wiring boot has been breached. That hole is one of two.
  12. Not the two holes. should have a square stand off lower on the frame.
  13. You should already have the "L" ones, they hold the radiator too. The holes are threaded from the factory. But who knows what happens in 25+ years to one.
  14. 2GU-21513-00-00 STAY, FENDER 1 and 2GU-21514-00-00 STAY, FENDER 2
