bansheegoon
    89' shee with 6 over swingarm, 19cc domes in coolheads, pwk 33mm, dune port, boost bottle, dynatek fs, not sure on exhaust type but mostly top end.
bansheegoon's Achievements
HQ Soldier
HQ Soldier (2/5)
3
  1. Because the shaft with the claw moves side to side. Trying to figure out if the lever is supposed to snug to the stator cover or am I missing a c clip or something
  2. There seems to be play side to side and the fingers came off the star and got bunched up. Figured that out but why is there play is there supposed to be a c clip on the shift lever side or just snug the lever up to the stator cover. Thanks
  3. You weren't around for that. I get some good laughs out of this forum
  4. Stoned again (medical card in Oregon) I don't want to know if I can port each side differently, this time its why does my bmx have big sprocket front small in rear apposed to my "banshee". Or any quad. Small in front big in rear. Only thing I can think is flexing forces on rear swinger would be harder to keep the chain on or a larger sprocket in front would put more side forces on the bearing on the output of the tranny maybe cause the inner race to walk out. I told you not to click! Anybody know or am I spot on with my thoughts
  5. Indeed and i m pretty sure you know this judging from the knowledge in your posts
  6. To be more specific take the air filters off and have a buddy kick it while you shoot a lil gas in each carb. Be careful if you have a back fire you might have a fire on your hands.
  7. What kind and how much. I'm a bargain shopper lol
  8. Research squish band and you should understand what happens when low octane fuel gets compressed too much.
  9. X2. The piston goes down 2mm further and 2mm higher then stock stroke "4mmsttoker". The piston would smash the head. Has to be cut for the piston to go up further.
  10. Sorry buddy too much effort. Basically you can buy fuel that is oxygenated and other chemicals added that will produce a faster burning bigger explosion at tdc. Sunoco 110 doesn't have that its just higher octane leaded because lead raises octane. Once people figured out it was polluting the lands with lead dust they sought alternative octane increasers. They figured out alxohol would do it. Ethanol. tl;Dr. Sunoco 110 will work well with high compression. Not performance enhancing
