Zillaguy
    2
Zillaguy last won the day on December 18 2013
Zillaguy had the most liked content!
3 Followers
About Zillaguy
  • Birthday 02/23/1977
    Attica,MI
  • Interests
    My family, my business, Banshees, Quadzillas, Maico dirtbikes (400cc and bigger), guitars, 420 time, the sound of a 2-strokes coming on the powerband.
Contact Methods
  • Yahoo
    Thevillian45@yahoo.com
    94 frame up restore all SS hardware.. Frame is GM Aqua blue metallic, black Maier plastics w/carbonfiber tank and rad cover/Magnum blue factory washers (billet anodized cross drilled fender washers), black Quadboss seat cover, DWT red label wheels w/Holeshots all around. Alba Pro-Elite +2 gullwing A-arms, stainless braided brake lines all around, billet tie-rods, polished oversized rad/clear rad hoses, ASV levers (brake and clutch w/rotator clamp on master and dust cover on clutch) Coolhead 23cc 4mm domes, 65.00mm bore 795 Wiseco, stock cyl aggressive dune port/4mm, case matched/gasket matched, Hotrods 4mm stroker long rod, adjustable timing plate +7,tors elim stock carbs 32.5 pilots/350 mains, Pingle dual feed, Taylor Spiro-Core wires/MSD 90 degree plug ends, FMF golds, VF3's, 3/8's reed spacers,K&N pods w/outerwears Chariot clutch pusher, Tyson cut trans, Driveline clutch,Cascade shift star, modded shift shaft, Mull detent bearing, billet impeller/Mull billet gear, Hinson clutch cover, Trinity billet stator cover, tapered bearing carrier, chrome Dura-Blue +2 axle, and a bunch of polished or billet parts.. Next year 33mm flat-slides and elka stage 3 long travels up front and stage 3 rear w/Elka link.
Recent Profile Visitors
2,164 profile views
Zillaguy's Achievements
HQ Soldier
HQ Soldier (2/5)
61
  1. I have two kickers with the "Holyman Kicker Mod" rattle free Sent from my LGMS210 using Tapatalk
  2. The progress so far on my new drag build. Its a Stellar modded stock chassis, Stellar -2+2 dual arm front end, Tyson +12 swinger, Mod Quad gun drilled axle, Lone Star front hubs, 14 Extremes 80" RO on 9x9's (still not sure if im suspending it or going rigid), 10mil Super Cub on alky, 38 PWK's, RDZ SF/BB out the left. More pics to come as i make progess. Sent from my LGMS210 using Tapatalk
  3. Those are different aye?? I wonder what they'd be comparable to.. Maybe Toomey?? Sent from my LGMS210 using Tapatalk
  4. You must turn down the end of the drum to a 15mm od, 7mm deep Sent from my 5065N using Tapatalk
  5. Pro-mod gets a 6902 bearing on the drum, every other dog cut, modded star, shift shaft, and a bearing on the detent arm. Sent from my 5065N using Tapatalk
  6. These still available sheerider? Sent from my 5065N using Tapatalk
  7. Permatex Motoseal is equivalent to yamabond. Wherever you got the Grey RTV should be able to get it for you. Sent from my 5065N using Tapatalk
  8. Dodge Caliber? Sent from my 5065N using Tapatalk
  9. I use a 6902Z available at any good bicycle store. It'd used in mountain bike hubs Sent from my 5065N using Tapatalk
  10. Take it apart, the bushing walked out of the gear. You may get lucky and be able to drive it back in. You may have to replace the gear though too. Sent from my 5065N using Tapatalk
  11. Timing plate arrived safe and sound, thank you sir Sent from my LGMS345 using Tapatalk
  12. Did you get it? Sent from my LGMS345 using Tapatalk
  13. PM sent Sent from my LGMS345 using Tapatalk
  14. Payment sent Sent from my LGMS345 using Tapatalk
  15. Ill take the timing plate, whats your paypal? Sent from my LGMS345 using Tapatalk
