Dmx
Everything posted by Dmx
  1. I dont need the 2-1 intake anymore so if someone wants it, just pay shipping and i'll post it. Im from Finland.
  2. 40mm lectron worked really well in my dune ported 350. I had yamaha exciter intake and oversized bowl, 6-2 xl metering rod and powerjet opened a bit. Going to stock carbs now and see how it feels like, different porting though.
  3. Pasi had few+couple beers, just another day at the office
  4. Yeah well this sucks cause i believed this topend had some shredding time left before next bore&pistons. Ive been thinking that crank will be 4mill and dune ported stock cylinders, better pipes&carbs for it also. Now i have t5`s and single carb, ss/sb dune ported. It depends what is available at the time i have the money. I think it would be bit cheaper and easier for me to have a whole bolt-on motor shipped here than collecting new/used parts here and there. Just have to get some money and start searching the next motor with pasi.
  5. Youve seen like this before? Maybe i put it somewhere around 160-170. Yes this is awesome, and sweeeeheeet! Time to go bigger. These cylinders are done, crank too. Skeeter you think banshee motor wrecks are common here in Finland? I have some doubts on that...
  6. yep thats how ive done it before without problems, bare hands and little help with screwdriver- this just got me thinkin WTF...just have to blame the builder goddamnit.
  7. Let the pictures speak, max 15hours on topend and left side died. Is this usual when not using proper tool for wrist pin clip? I did double check and it was seated correctly during the top end assembly, but "kinda" looks like it wasnt hahahh.
  8. The best and the only one in Finland.
  9. I have no idea with your jetting but lets see some pics of your custom tube intake
  10. I ran out of gas (e85) few Times With My previous 4poke atv, it had a afr wide Band meter on it and it went really lean when fuel was running out. Jmo but i think it can melt piston or fuck Something else up With wot.
  11. Heres my second test drive, clutch is fine now.
  12. Have you checked the ohms with meter, stator and ign.coil and all.. Here is good info www.dfn.com/agservices/elecfaq.html
  13. Thanks for replys guys! Yes i installed the pressure plate wrong, my bad. Lucky me because it didnt hurt anything. I wasnt going to even start her again before knowing and fixing this issue. By the way the lever came a bit softer after i reassembled the pressure plate and adjusted the push rod again.
  14. I did first start on my -87 banshee just today after teardown/rebuild and heard a loud grinding when pulled the lever in. Assembled the clutch with new driveline billett basket and driveline drag clutch kit, adjusted the pushrod also. Lever feels pretty stiff but i think its supposed with those HD springs. Here is video, a bit over 1min you can hear the sound when i pull the lever. And yes, i know it has really rich mixture.
  15. WOW, i thought that it was just a joke, well it still is
  16. ^^so you need to rejet again. what carb you used before swappin back to 2 carbs?
  17. he must have saved all the receipts from gas station too...LOL
  18. ^^ "It has a 5.5 gallon see through tank" How cool is that
