bbd
bbd's Achievements
**YARD SALE** Never made it past Rolling Chassis
bbd replied to bbd's topic in For Sale - Parts & Accessories
SOLD: Engine Mounts Shock Linkage & Dog Bone -
SOLD: Works dual rate front shocks. -
SOLD: A-arms & tie rods -
SOLD '03 Raptor rear shock -
Bad Ass ride. I'll take it. You take I.O.U.'s?
SOLD Thumb throttle assy rear disc rear sprocket MAKE ME AN OFFER.....I'M FEELING GENEROUS!!! -
SOLD AS OF 7/25/12: front brakes rear brakes rear hubs (spindles) kill / light switch mini lights coolant bottle / bracket -
The Works shocks are 14.75" from center to center. overall length is 16" -
Arms are +2+1 and so are the front brake lines. -
I don't have the engine anymore. I don't remember the set up of every quad I build, sorry. -
link to exact item: http://www.knfilters.com/search/product.aspx?Prod=RU-0610 -
I am giving up on my custom build, it's been awhile since I had the time to put into it, so please help contribute to the 'Fix My Old Boat Fund.' Add shipping to all items unless you pick it up. I am near Chicago, IL. I will combine for shipping. I will make some deals on multiple items. http://s1168.photobucket.com/albums/r484/Photokolektor/ New Parts in Orig. Pkg 2x K&N pod filters w/ black outerwears (RU-0610 3.5"OD 5"L 2 1/4 FLG.HD) $ 50 FMF SST Gold exhaust pipes $ 300 FMF PowerCore2 Titanium silencers $ 175 Aluminum Pro-Peg Nerfs with black nets $ 125 Heavy Duty Aluminum swing arm skid plate $ 50 ProDesign EZ coolant drain plate $ 10 Aluminum clutch lever & perch $ 10 MotionPro CR twist throttle w/ 2 hand pieces & 1 cable $ 35 New Parts Installed on Rolling Chassis FRAME - freshly media blasted & powder coated candy apple metallic red $ 350 Works dual-rate adjustable front shocks w/ reservoirs including mounting bolts & hardware $ 450 Action A-arms, tie rods. Fully adjustable. Powder Coated silver. Including mounting bolts $ 250 Coolant bottle relocate bracket w/ spark plug holders. Includes coolant bottle & hoses $ 15 Polished mini headlights $ 25 Used Parts Aluminum Radiator with Billet cap $ 50 MSR Dominator Aluminum handlebars with pad $ 20 D.I.D. Gold O-ring chain 520VM w/ master and clips $ 45 Gas tank $ 25 Rear Spindles $ 10 Rear sprocket and holder $ 10 Rear brake disc and holder $ 10 Dog bone & shock linkage $ 10 Rear axle carrier with new bearings and grease zerks $ 45 Wiring harness $ 25 Kill switch / Light switch $ 5 Thumb throttle assembly $ 5 Engine Mounts $ 5 Reed cages $ 5 Front brake assembly w/ new braided lines & polished Billet master cover(calipers, lines, master, lever) $ 35 Rear brake assembly w/ new braided line & Nacs block off plate(caliper, lines, res., master, lever) $ 25 Raptor front brake master cylinder(it is silver) with alum lever $ 25 '03 rear Raptor shock $ 60 http://s1168.photobucket.com/albums/r484/Photokolektor/
only in WV
