Well, I have been having trouble with my idle since I rebuilt my carbs. Started by placing stock jets in when I shouldn’t have but I got that changed back. When all was said and done it struggled to idle. I ended up installing a TORS elimination kit and got back down to business on working on the idle. The bike starts on the first or second kick and it will idle fine with the choke on. But when I take the choke off it idles slightly higher, idles for 5 to 10 seconds, and then dies. If I give it throttle the start of the idle it responds fine but if I wait until the idle starts to slow it bogs when I hit the throttle and eventually dies. But if when it starts to slow I pull the choke back out it usually recovers and idles again. This is the same thing it was doing before I installed the TORS elimination kit.
I have my air screw backed out at 2 ¾ turns like it was before I rebuilt the carbs. Adjusting the air and idle won’t seem to fix the problem, it will just idle higher and then die the same way.
Another thing that has me baffled left carb (choke side) will leak gas out of the overflow. Every time I have had the carbs off (about 5 times now) I have checked the floats and they seem to working fine, and when I did the carb rebuild I replaced the plungers.
Any help would be greatly appreciated
