registered user
    20
Everything posted by registered user
  1. dude just go to ace hardware and get some threaded rod and 2 washers. put it through the swingarm with a socket of appropriate size on each end and blam youll have em out in less than 5min. put new ones in the same way. should be video on youtube showing how if you dont understand
  2. timing affects how well the pipe works also. ive never done any testing with the stock box so i dont know if alot of static advance would be good or bad. this is where a programable unit really has the advantage. can create a ideal curve across the board
  3. whats that old sayin. dont count your chicken until they hatch
  4. whats the 3cylinder with billet cases weight ? complete engine minus carbs and pipes
  5. that dont make sense. friend gots a 250 bored .050 so its a 300 now i think. thats what they tell me anyways. this math shit is confusing
  6. wiseco crankshaft eh. you must be new to the sport
  7. selling shoes in the day and grinding cylinders in the bathroom at night
  8. a legitimate performance shop should have a dyno within arms reach. without it you will spend alot of time going around in circles with little progress forward.
  9. i think alot of shops nowdays are nothing more than parts changers working out of a 10x10 shed behind the house. half the work is probly farmed out to a third party so all they really doing is assembly. rarely is everything done in house these days
  10. its all good man. looked back on alot of shit i did and wondered why the hell i did it. im sure people tend to replicate what they see from pictures. pretty sure near every pic around here is knifed and Veed on the bridge so its understandable you would do it similar. try to think outside the box for a better way. maybe look at how other cylinders are and gather some ideas. get a peek at calvins jugs for some ideas. on the stuff i do theres not one sharp edge except where the window joines the bore. but everyone has there own method. keep at it and youll get it sorted out
  11. why not make the bridge more like cpi jugs . not that im a expert in aerodynamics or anything. i just never liked the knife edged V shape stuff
  12. i wouldnt be concearned with the boyesen ports. i dont see why they would hurt anything not sure what you can do with the tunells. to be honest theyre not the best shape to begin with. large radius from entry to exit would be better but i dont think thats possible and thats one of the problems with inline twins that have the jugs close together. maybe with epoxy or weld you can do something ? most people dont like the engine full of epoxy so i would just do the best you can and thats all you can do
  13. shit them cracks aint nothin. i got weld all over in mine. bottom of the port, both aux dividers and a pressure relief hole above the port
  14. i was thinking the same thing on the boyesen ports. with them that small they probly arent making much difference either way. if the casting was thick enough to make them quit a bit larger im still not sure they would make much difference because the main intake appears it can be made rather large. and the piston windows are your boyesen ports so to speak. some engines dont use piston windows and there for rely more on large boyesen ports
  15. just send it all to sprinklerman racing. he will get it whipped into shape for ya. porting and measure your jugs. the whole enchilada
  16. i wouldnt drop the exh floor. you will gain nothing from it. but you might open a escape route from the pipe to crankcase, but you may already have that problem. put cylinders on and see if theres a hole under the skirt. if its small hole you should be ok, if its large hole you might want to reconsider what height you set the cylinders. but having no escape hole is the best having a paper thin bridge is not a good idea but on the other hand i dont see a reason to keep a mile wide bridge either.
  17. to you maybe it makes more sense. but not to me. do it how ever you feel comnfortable is what it boils down to
  18. thats not really a issue with sleeved cylinders. alittle slip wont hurt anything. even with plated cylinders its not a huge deal unless your slipping alot in the same area and put a big gouge in the plating. once you get a feel for the tool its pretty rare to slip
  19. you can put a small arc on the window floor to help the rings. but it sounds like the piston at bdc will be well below the exh floor. i see no reason to hog out the bottom portion of the exh to match the piston. what happens at the window is as important as the tunell imo
  20. just wait until you have the new pistons and set your desired timing based on the new pistons. since your leaving the cylinders at standard height maybe you can drop the trans floors to the piston top ? i probly wouldnt grind down the exh floor however
  21. you got a tool to work on the transfers or you just gonna leave them alone ? whats your plan for where the cylinder height will be ?
