registered user
    20
Everything posted by registered user
  1. bruh yz490 is crap. sorry i didnt respond sooner. been real busy
  2. start over with serval or cub monoblock.
  3. i never looked that close at factory welds. some of them dont look good but i wouldnt worry much about it. for normal riding its good enough
  4. http://trickracing1.net/Trick_Racing.html
  5. looks good bruh. get some ebay junkers to practice so u dont f up your good shit
  6. the more i look at it i think its partially a copy of dat chariot cover. i bet they stole his design and hes pizzed im sure. fukin china cant even design there own shit
  7. made in china? jesus christ it probly wont even fit right
  8. check it out broseph https://www.ebay.com/itm/313796284227?_trkparms=amclksrc%3DITM%26aid%3D1110013%26algo%3DHOMESPLICE.SIMRXI%26ao%3D1%26asc%3D20191002091506%26meid%3D2347cd42594640c0b351baee963a3e6a%26pid%3D101096%26rk%3D2%26rkt%3D6%26sd%3D265407664444%26itm%3D313796284227%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DSIMRVIMLRV5WebV1_0%26brand%3DTarazon&_trksid=p2332490.c101096.m3021&amdata=cksum%3A3137962842272347cd42594640c0b351baee963a3e6a|enc%3AAQAGAAAB8K3mnX8pe%2Fg%2BfFyrpfFjBnUAztsFIydCN8zvp3%2B0QJQNVgD38xWit0sAHQsqzb%2BjfNj%2FvVKCw6Dy8fWc%2FAPV6a1XhJi5QtBdlUcF0Fg30wB8yK40acRa%2F7RWi9OqAk4QAOGNSmh59HFVnmNL76MmSHS3wzMu1AbHZsYaRXE9y726e786yAlB5QA4k4bzhTeEB2OF%2F7aCWJcOmJW8YSm0%2FFEXgFtE%2BuWob9ypjkc%2FCyhbhAwkGXNt9ikO5u2AUoMqxODTnC3NW5gd5jd9yW%2Fi2zGBXjwvfWijawYKpmq%2FeqmXN9rAxU1Qi8QYfY0CBep2uondbhHbgeUasXYg911D4QickyInC7Af4iKX242xNdCOISlnzpgTIg76uTEc3gmdNsNaQ3oc6%2BrdiDTlBpfGe%2F92W83ABLV99tNMrBrHaoocPflyKcw8%2BDXEJabJTsJwpdwBALHf7zXcQjF2B2Cq1pdQCFrzXCE3axG2kRe51HOrT2ACWJOi9qfJsB4LUAy%2Fn2FBcd%2FQ4r%2B%2B2lU6p%2BIKqB3iBHBQM0FCHEMnFDuIj4sRBT7U5cliWf%2BZ8YEWYxsyDavSt%2FB%2FYD6CMWKD3mS%2F46BGipOHFqzjquJShpQzGwR5Gf66faZeX%2B%2BHFJZkoa3d%2F2akkMQzcCp2%2FEECWaIKyak%3D|ampid%3APL_CLK|clp%3A2332490
  9. dat chariot cover looks dope. modqaud is decent but weigh 42lb
  10. naw the shaft cant snap. chinesium steel is way stronger than that
  11. your ol lady will send u packing if you spend 10g on a banshee. spend 3g and buy new dirtbike with the rest. in 2019 i picked up new husqvarna 250 2stroke and its badass
  12. just wondering. why were you using a different bearing on both sides ? normally when the inner race has to be pressed on a shaft and the outer bearing is pressed in a bore or has a clamping force applied, c3 is preferable as there likely wont be sufficient clearance between inner race/rollers/outer race. i could see the 305e skidding rollers if it wasnt c3
  13. did u use c3 ? otherwise it should be good to atleast 14k so over speeding i dont think was a problem. is the yellow cages brass? i used the plastic ones on other engines and never was any trouble
  14. did u try messing with da powerjets. maybe it was just to rich. i had mine open to far and it was a turd until i closed them up a bit
  15. im not aware of any spring that gets stronger with time but i doubt that was the reason for removing springs. likely its a quick down and dirty test of the clutch system to see if heading in that direction is worth while or look else where. with big tires and alot of paddle and alot of traction i could see it bogging any mtr if the clutch locks to much
  16. u gots alota power it sounds. skeeter dont even got that much
  17. how many passes u make and how often u want to change sprockets? aluminum is the lightest option but doesnt hold up as long. steel weighs a metric ton and sucks balls all the way around really. chromo isnt much heavier than aluminum but shits expensive. price wise it might b a wash for 2 alunimum or 1 chromo but youll change alinum more often
  18. do u have advance timing? +8 should clean any oil out
