registered user
    20
Everything posted by registered user
  1. this sounds somewhat plausible. im sure most of the heat is carried away via the water but there would be some radiant heat dissipated through the exterior of the cylinders but how much is the question. since theres no fins on the cylinders I would say theres not much heat shed through radiation. how much of a thermal insulator the PC is would be the other question. even if it was a great insulator, im doubting theres much heat dissipation through the cylinder exterior walls anyways. so I would guess the PC wont make a huge difference in engine temps but maybe im wrong
  2. I bet you could slice it with exacto knife and super glue it back together. remember you heard it here first
  3. got some for my '16 ram from carcovers.com iirc. cant even recall the price but theyre decent
  4. whys everyone obsessed with how far they can advance the timing?
  5. a lot of dirtbikes use the rubber pieces with internal threads, some exactly the same style as claudes, some are slightly different but same concept. the main thing that breaks down the rubber over time is when the pipe bracket is not parallel with the rubber isolater. one edge of the rubber is being compressed and the other edge is being pulled apart if that makes sense
  6. 29l might be that cheap shit from ebay. wang?
  7. hmm I wonder if that's why so many cases end up with chain wack . seems perfectly plausible to me
  8. devcon is expensive just to use a small amount and if the remainder isn't stored correctly it goes to shit. seems like shelf life is only 1 or 2yrs in factory sealed container so you can imagine after its been opened
  9. iirc windows live movie maker can cut out all the nonsense and edit the gopro video to only the important stuff. if your computer has windows7 or above you should have it already installed im sure. been a while but it seems that's how I was doing it
  10. these diferences are miniscule and could have several explanations why. bore diam and casting variances are two i can think off top of my head. oh and dont forget human error of the measurments
  11. seems alot of tss around here. are they new original ideas or something 'borrowed' that others have already tried ? its not everyday that someone can lay claim to a new concept in 2stroke tech. which leads me to believe tss may be nothing more than a new twist on someone elses idea thats already been tried or rather a copy of someones ideas applied to a different engine. neither of which is tss in my book
  12. porosity happens when theres contamination in the puddle. likely those shops havent welded on old cylinders much. theres a different aproach than new material
  13. I have one '03. if I ever decide to let it go ill let you know
  14. from walmart get a house candle and run the bit in it every so often. cuts a lot better https://www.walmart.com/ip/Mainstays-6-Unscented-Pillar-Candle/16783708
  15. im gonna start making instructional videos and sell it to you guys. welding up holes is not hard even if its large hole the size of a dime.
  16. dumb fuks make a mountain out of a mole hill. pretty sad
  17. anybody that makes a big deal of that little hole has obviously never welded before. good night john
  18. hahaha u must not of seen my ktm or driveline cylinders. that little hole doesnt amount to a pimple on a horses ass. take longer to plug the machine in and turn on the gas
  19. that could be welded easy. do it quick and dont pour a ton of heat to it any longer than necesarry or the casting pulls away from the sleeve and you risk warping the thin area of the gasket surface. between 5-10sec and it be good to go
  20. your not mechanically inclined I take it. clean the area alittle with a dremel if you have one. if not no big deal. put piece of tape on back side of hole, mix alittle jb weld with screw driver or something and fill up the hole, done. local machine shop would probly weld it free if they already have their tig machined fired up
  21. lightweight you say ? I bet jt will be all over this just give him a min to chime in
  22. nobody hates china worse than me. chinese tools will never be in my garage. pay 2x more for same made in usa bits i dont care
  23. got that right. motor footcontrol and straight piece $30 cheaper on da internet. 10 bits at $7 vs $15. saved yourself $80 there. ya dumb basterds
  24. goddam i already said straight piece is far cheaper on ebay .what part of that cant u comprehend???? said bits are half price most anywhere. do u understsnd ?????
