m671054
    4
Everything posted by m671054
  1. On a hill chassis? youve got to much money. but that will be a good durability test
  2. For those running billet cases do yours use a adapter for the ign side seal? i have a set (maybe racers edge?) hat runs one and i cant get it to seal on the od. what different seals are used for big bearing vs small bearing setups. gotta get this thing going as my other motor just bit the dust.
  3. Be sure the ground to the cdi is good. mine would spark once in a while with no ground hooked up to the cdi. fixed the ground fired right up
  4. Right around 40lbs at that height
  5. Whats a regular lockup? Answer all these question and youll be suprised at how good the info you get will be. i already see 2 problems in your setup. i bet there is 1 more
  6. Primary ratio? tire pressure? hows it pull the 14-41? can you pull more like 15 or 16-41?
  7. Need the fender supports that go from the frame down by the motor out to the fender. need both sides and hardware. Also looking for blue uncut rears. let me know what you got.
  8. More info. Weight of bike and rider. type of sand. tire pressure and ro. gearing front back and primary. clutch spring and lockup type. just a few more details to give you an accurate suggestion
  9. so then thid statement is incorrect? convergance would cause this?
  10. Also post any good books or computer programs to learn about msv, dome profiles, compression ratio calcs etc.
  11. Which one is tighter on the outside? diverging or converging
  12. Im not sure how to word this correctly but here goes. In the squish band how does increasing the angle affect power ouput. example if your at .045" on the outer edge and .055" on the inside of say a 10mm wide band vs. .045"-.065" or parralel at .045 all the way. also explain proper terminology
  13. Devcon has 2 that work good they have aluminum liquid f2 that is pourable and another that is thicker ( forget the name of it). i got mine from fastenal.
  14. Does a banshee and 450 tie rod end have the same taper?
  15. Look at the car parts or hardware store for liquid electrical tape. works good for sealing chaffed wires
  16. Any thought to how your going to time it going together? no key is used on flywheel
  17. Your sure its not hitting the stator wiring or connector
  18. If it was fuel it wouldnt recover more than likely. when they starve out they fall flat and run real shitty. my initial thought was not enough arm weight as well but wasnt sure if it would recover as well. i guess with the added rpm from 5th gear it might add enough force to lock back up.
  19. Jmadd whats your thoughts on the 15 out the back and no lockup
  20. Swapped coils and problem stayed on same cylinder. id say you figured it out
