answ3r
    Qc, Canada
    '99 banshee
Recent Profile Visitors
1,037 profile views
answ3r's Achievements
  1. I have a -1" and love it all around. For any steep hill with moderate power I wouln't go any shorter tho.
  2. With the DC one, can you run it without a battery ? (For leds). What kind or rewiring need to be done ? Thanks !
  3. What is the difference with the standard Wossner ? They sure do look very good !
  4. The do had a good bunch of low end punch, I can pick the front end up a lot more easily at lower rpm now.
  5. Seems like we can't edit posts... On their website wsm only list forged under "race pistons" with added boost port. That's what you have ? Anyone tried Vertex too ?
  6. Ok to anyone that might help, I read that boring them out reduces velocity so you should jet up (bigger) a bit.
  7. I read that cast pistons had better lifespan than forged piston but those WSM almost make me change my mind. A lot of place I read "All I use is wiseco", it's what i have and I feel going another route. Debating pro-x, wsm (cast and forged), and wossner. How many hours did you ran it on in 6 years ? Also the top of my piston were a LOT cleaner than that with 32:1 hypertech SSS oil. Don't know if it's supposed to or not.
  8. Just got mine from FAST, can't wait to try them out ! I'll be running stock pipes in winter and pro circuits in summer.
  9. Hi, I brought my banshee with the stock carbs bored to 28mm and I'm wondering what it is THEORICALY supposed to do to the jetting. Say ProCircuit recommends a 260 for their pipe and a stock banshee should I go bigger/same/smaller with the bored carbs as my starting point ? I was wondering the same with Vforce4 reeds and mild porting if I go down this road. Thanks !
  10. When properly jetted it should start first or second kick (usually second in cold weather).
  11. As the title says, I need an axle carrier in good shape with the middle sleeve. I don't need the bearings/seals. PM please. Must ship to Canada by USPS. Thanks !
  12. How much ? You'll let me know once it's sold ? Thanks !
