Is it too low? I've raised the idle before. I also pulled the choke out then put it back in and it turned off.
http://www.youtube.com/watch?v=wiLg8n29fHY
Then get the aliens, same as 916 except it doesnt come into one but have a listen to the sound of the 916 maybe you might change your mind. I have a video in my sig of the 916's.
Well the aliens and 916's are the same head pipes just different silencers. But the sound that the dmc 916 silencers give are on a totally different level to any other set of pipes.
Well Ive ridden banshees with dmc aliens, dmc 916's, fmf gold series, toomey t5's and toomey t6's, all on stock banshees. Best bet would be dmc 916, toomey t6 or dmc aliens.
ok well give me an accurate jetting for this setup
Mods: DMC 916 pipes, K&N filter with lid on, stock carbs and stock everything else.
Elevation: 3000-4000 above sea level.
Tempertaute where I ride: 45-60F
My current jetting: 280 mains and pilots is at 27.5, dont know what needle is at.
Im not going to change my jetting but want to know if im close to the right jetting since I cant do my own plug chop.
When you look at the slides there should be a notch at the bottom of it. when putting the slide in the notch should be facing the airbox and the slides only go in one way so if the notch is not facing the airbox, its on the wrong side. Someone correct me if im wrong.
Like this:
